Leaking oil pressure sensor
  • Bartman
    • May 2012
    • 200
    • Jefferson, Georgia
    I have found that the drip of oil that I keep getting is coming from the oil pressure sensor. I took it off and put a new seal washer on and cleaned it good. Then I took a 20 mile ride. When I got home and checked there was another drop forming on the screw and wire.
    I believe that the old internal seal is the problem.
    Anyone ever sealed the sensor? Of course I would have to have continuity!
    79 XS11
    If the sensor you are referring to is on the bottom of the motor, that is the neutral light switch. The oil pressure sensor is on top the motor near the starter.
    • Bartman
      • May 2012
      • 200
      I may be wrong and you may be correct. Yes, under motor, left side behind shifter.
      79 XS11
        I have successfully (sort of) sealed those up with JB weld before and it stopped the leak for a while but did not last. I ended up just eliminating the switch altogether by replacing it with a bolt. New switch runs about $20, GL.
        • MarkD
          • Jun 2013
          • 488
          • N. Michigan
          I have replaced the neutral switch, by the shift lever, bottom of engine, port side. Have not had any leaks there. There is a small brass washer for it. Could be a leak above it from somewhere, making it appear the switch is leaking?
          79 F
          1967 Suzuki X6 Hustler
          1973 Suzuki TM 125
          1979 XS1100 F
          2005 Kaw. Vulcan VN800
          1991 BMW K75
          • James England
            • 3039
            • North of England
            Personally, I'd replace it with a new one. Oil leaks of any sort are too reminiscent of my British bike days. A little bit of oil goes a long way when riding..it usually ends up all over the bike, foot and tyres. For all the cost, it's not worth mucking about with if the internal seal has gone...
            • MPittma100
              • Aug 2011
              • 2359
              Oil Leak.
              +1 on replacing the part with a new one. Be done with that problem. When that type of switch begins to leak, there is no repairing it.
              Mike
              1981 XS1100H Venturer
              K&N Air Filter
              ACCT
              Custom Paint by Deitz
              Geezer Rectifier/Regulator
              Stebel Nautilus Horn
              EBC Front Rotors
              Limie Accent Moves On In 2015
              Mike
                The neutral switch looks identical to the one on the XS650. I have replaced a leaker on that bike. If it's the same, a new one will be available and the way to go.
                • Bartman
                  • May 2012
                  • 200
                  I went to the barn and took the one off the spare motor. I cleaned it and put some Silicone on top and let dry over night. Just put if in and will try another ride later today. I don't like leaks either and if this doesn't work then I will come off the hip and get a new one.
                  79 XS11
                    2H7-82540-00-00 shows obsolete. (NLA) I wonder what's different about 136-82540-00-00? It's used on a lot of bikes. Without removing them from their respective motorcycles, they look the same.
                    • ESJr1642
                      • Jan 2012
                      • 103
                      • Groveland, FL
                      Superceeded number-off Yamaha site -
                      Part Number: 4KM-82540-00-00
                      1979 XS110F, Stock
                      1980 XS1100G, Mostly Stock, gifted to my son.
                      2000 YZ 250, Sold
                      2002 YZ125, Sold
                      2009 Royal Star Venture
                      '94 Pontiac Trans Am, 25th Anniversary, For Sale
                      Ernie
                        Strange. The XS650 switch PN changed to 136-82540-03-00. I assume it is not a match.
                          • MPittma100
                            • Aug 2011
                            • 2359
                            Oil Leak
                            +1 on that company (NWVCP) Phil. I have used them many times. Good people to work with.
                            Mike
                            K&N Air Filter
                            ACCT
                            EBC Front Rotors
                            Mike
                            • Bartman
                              • May 2012
                              • 200
                              Thanks guys, the second one is wet too after my little ride so I will be ordering a new one.
                              79 XS11
