Head light relay
  • petevan
    • Sep 2003
    • 35
    • Bountiful, Utah
    Head light relay
    Within this past year I noticed that my headlight did not work, in result I replaced the light bulb (most likely culprit) still nothing! I traced the wires and everything was in check until I got to the head light relay. I had no way of testing this part, except to bypass the relay using a strand of romex wire. To my delight the light worked. I went to my local shop and it was there that they informed me the part was discontinued. For a temporary fix I installed a single pull double through automotive switch. However, ever since I replaced it I have not been getting full power out of my light. I made sure that my switch's amps where rated sufficiently. Since I installed this switch I also have been looking for a relay at local scrap yards with no luck!!! I have even emailed a few scrap yards across the country and they have not responded. SOOO does anyone have an extra relay they are willing to sell , or I am opento suggestions on how to bypass the relay in a way I can get adequate power.
  • newmaac
    • Dec 2002
    • 369
    • San Jose, CA
    I should have a few of them.
    I am not certain that they are interchangable though. What year/model are you referring to?
    Let me know what you need, and a shipping address, and I should be able to get it out on Monday.
    $5 work for you?
    Mike
    1980 SG "Angus"
    • petevan
      • Sep 2003
      • 35
      • Bountiful, Utah
      Newmaac-
      Thanks for your quick reply I really appreciate your generosity in helping me out. I have sent you a private message and an email ( if your address is still current) if you don't get either one I would appreciate a E-mail to Petevan@xmission.com so we can work out the details.
      Thanks again your a life saver, that has brought an end to a frustrating ordeal.
