CNC Machine work
  • gene
    • Mar 2009
    • 267
    • Weston, Fla.
    CNC Machine work
    Anyone know a good machine shop for XS1100 Heads? Im in Florida.
    Gene (Florida)
    1980 XS1100SG
    Accel Coils
    4-1 Jardine Exhaust
    • 4015
    There are a few Florida riders on here. I'm sure they'll chime-in soon. My suggestion to you is to call the smaller motorcycle shops (the old heads), and see who they recommend.
      What exactly are you wanting done? Just a valve grind, or ported/polished?
      Many people have removed the rough flash or tried opening up the exhaust ports and such and lost performance. If you don't know what you're doing (Or the shop) you'll make it worse, not better.
      If it's just for a valve grind, fairly easy to just lap them yourself.
      • gene
        • Mar 2009
        • 267
        • Weston, Fla.
        Has anyone used Millennium Technologies for head or cylinder work?
        Gene (Florida)
        1980 XS1100SG
        Accel Coils
        4-1 Jardine Exhaust
          Take the time to search for and read threads/posts by member Dan Hodges before spending money on custom machine work. Dan spent large sums to find there's little extra streetable power to be found in these motors and it gets very expensive. Worse yet, there's even less aftermarket support for this motor now than there was when he tried.
          If you're after more power, use nitrous.
          • gene
            • Mar 2009
            • 267
            • Weston, Fla.
            Really just looking to freshen it up. I bought the bike and it was rough looking. The #1 shifting fork was broken and the oil sump was sitting in the pan loose. So I really need to confirm everything at this point.
            Gene (Florida)
            1980 XS1100SG
            Accel Coils
            4-1 Jardine Exhaust
              For a 'freshen', you can do that at home. If the motor is beyond that, you'll be money and time ahead just finding another motor unless you're planning on a big-bore kit or are determined to keep it 'numbers matching', then you'll need to find somebody who can do a proper job of boring the cylinders. Generally, if the head is bad enough that lapping the valves won't 'fix' it, it's too far gone to do anything with it. Valve seat wear is what does these in, and the seats aren't replaceable....
              Rings, bearings, pistons, valves are all getting increasingly hard to find for these and not cheap when you do find them. Most owners are filing aftermarket oversize rings down to fit; not the best solution, but 'standard' rings are nearly impossible to find, as are 'standard' oversize pistons.
