I'm trying to crank my bike with a cb12a battery that I had from my previous project. I'm just going on a limb here when I say that I think this battery doesn't have enough cranking amps for an xs. Am I right?
xs battery question
xs battery question
Marc Garcia
Simplified wiring
DynaTek green coils 3.0 Ohms
High performance spark plug wires
Blade fuses
Motoscope Mini Digital speedometer
R6 start button
Zx6 left controls
Mikuni BS36 Carbs (Gold tops)
Mikes XS tapered pod filters
4-1 headers w/open exhaust
Tkats fork brace
previous toys
1981 XJ650
1979 KZ650
1978 CB750
1971 CL350
2008 VZ800Tags: None -
Correct. From memory, the correct battery is a YB18, an 18 amp/hour unit. Your 12 amp/hour battery just isnt going to cut it.1980 SG. (Sold - waiting on replacement)
"A man should look for what is, and not for what he thinks should be" Albert Einstien. -
If it is just for test purpose just boost from another battery to get it going.
should run on any 12v battery above 10.5 volts1981 XS1100 H Venturer ( Addie)
2004 Kawasaki Concours. ( Black Bear)Comment
This is good news! By boost from another battery do you mean run two batteries at once? as in plug up my cb12a onto my bike then use cables to boost off another battery? this sounds interesting.Marc Garcia
Simplified wiring
Blade fuses
R6 start button
Zx6 left controls
Tkats fork brace
previous toys
1981 XJ650
1979 KZ650
1978 CB750
1971 CL350
2008 VZ800Comment
I once used my truck and jumper cable to start my Kaw ZL600. Pulled them once it started.Keep the shiny side up
1979 XS1100SF
Mac 4-1
Drilled airbox Uni filter
Vmax bars
Virago 1" shorter shocks
30K miles
http://i1228.photobucket.com/albums/...429_135845.jpg
1981XS1100SH
'80 G Forks and Triple Tree
'80 G tank
Mac Turnouts
Virago 1" shorter rear shocks
SH Headlight
http://i1228.photobucket.com/albums/...psd6adaae1.jpg
61 Wife
83 Son
86 Son
89 DaughterComment
Two to start then disconnect the extra. Your "little" battery will keep it running while you do what ever test you need.
Phil1981 XS1100 H Venturer ( Addie)
Marc Garcia
Simplified wiring
Blade fuses
R6 start button
Zx6 left controls
Tkats fork brace
previous toys
1981 XJ650
1979 KZ650
1978 CB750
1971 CL350
2008 VZ800Comment
