Cheapest price fork brace???
    • 2101
    It is my understanding, that only Torozzi, Tkat, and hoop style braces are available for the XS1100. Is this correct? Obviously, I'm leaving out the used market.
    I believe you are correct, least those you've stated are the only braces my research exposed as available for our bikes.
      • 2101
      It would've been nice if the Specials came with forks and brakes like the Virago. Hmmm . . . swap anyone ?
        Although this ATK looks like it will adapt to either the Standard or Special by spacer choice, the bore when tightened, was loose on my '80G but fit well on the SF.
        Different machined diameters and fork manufacturers between the two model bikes. One is Showia, other is KYB. No interchangability including that brace.
          Available from various sources. Search XS650.
          Had one of these on my 11 when I went off the road last fall. It tweaked out of shape and I had to remove it. It was holding the forks twisted.
