I finally got the needle valve seats and installed them. Cleaned out all the jets once more, new needles, set float heights to 23mm in all carbs, pre-synced the carbs with the 'bread-tie' method (seams to make sense), reset the idle mixture screw to where I thought it had been and installed the carbs... (sorry for the run-on)
Can't get it to stay running. Cranked and cranked and cranked some more on all choke settings, with and without throttle. Seamed best to use full choke with no throttle but even then it would start and then immediately quit. A couple of times after I released the starter button and things had stopped for a second, the engine turned by itself (if that makes sense). Once it backfired VERY loudly out the exhaust after I'd released the starter button. Enough to make me nearly soil myself....
I am trying to start it and work out the carb problems without the stock airbox on due to the difficulty in removing and re-installing it. Any suggestions to getting it running?
Could the idle mixture screw not be properly set and cause the hard starting and backfire? If so, would I want to open the butterly more or close it more? I reset it after the pre-sync.
Any help?? Please, it's too warm to be working on it - it needs to be ridden!
Tom Brant
Tom Brant
