Finally got my MNS carbs to stop leaking gas out of the float bowls but I'm having should trouble bench (pre-)syncing them. I followed the guide on here for pre-syncing them in the tech-tips but I'm having a strange problem.
When I go to set the #1 carb butterfly even with the screw all the way turned in it will still not open the butterfly enough to match the gap with the other three carbs. I'm not sure if there is a way to reset the adjustment but I can't adjust the part that turns it since it is slotted to only fit in at a certain angle.
Any ideas why the #1 butterfly would not be able to open as far as the others?
They are a set of 1980 MNS carbs for reference.
