I've been running 15w40 rotella in Excelsior for the last couple changes and it was perfect.
Then I really read the service manual and it states 20w50...so I switched over to Castrol 20w50, conventional oil. I ran Everwear oil system cleaner through it for a 5 minutes or so while I got my drain pan and tools out...
Got some of it for free from my my work, so I used it
Drained the entire system as best I could, inside the case looked SO CLEAN through the fill hole.
Filled with 3.7 qts of 20w50
Holy Cow, my shifting feels so slick now!!!
totally smoothed out my clutch when starting from a stop.
shifting through the gears, is quieter, less tractor like, but still way smoother than rotella.
