Hello XS lovers! When I bought my bike a 3 months ago It came with a set of FJ1200 carbs and I was wondering if any of you have successfully ran these carbs on your bikes? If you have how did you work on the Vacuum advance? Ive read on the Australian forums that you can plug up to your manifold and place some sort of restrictor on the tube running down to vacuum advance unit. is this correct would that work? I've also read that you can drill/bore your own port on carb number 2 but that sounds like unwanted work. Heres a pic of my tops I have looked at them over nd over. I'm almost positive that they are BS36's
They used to be gold tops before I painted them to match the paint job I gave my bike.
