not sure how to start this thread. but have been experiencing carb problems since last fall. all started with carb flooding over. took carbs off and found 1 float sticking.fixed that and started having backfire on decel. found out that turning out mixture screws helped . so now it is fall, so parked bike for the winter.now with weather getting nice decided to look at carbs again. got carbs off and disassembled. what a mess.so much crap in carbs. 1 float needle was wrong for this application.2 out of 4 floats hanging up bad on pins.2 floats not even usable. had another set of carbs to use for parts. took floats and needles out of spare carbs.both sets of carbs are off of 80s. completely cleaned carbs with cleaner and lots of air. used new floats in carbs and couldn't get float height right .found out floats were not even from side to side.after much adjusting i think i finally got them right . went by book specs of.906 or 23mm. are these right .bike is stock. did notice tho that my original set of carbs had 110 mains all the way across.the other set had 110 and 120 mains.whats up with that. should i use the latter of the 2 sets as this is what clymers says should be in carbs. bike never really ran smooth. i'm mechanically inclined.so any advice. just really want to get bike running its best.i don't exspect a new bike ,just one that runs good. any help would be great.thanks to all.
