Stuck idle screw
  • donebysunday
    • Oct 2012
    • 1737
    • New Berlin, Wi.
    Stuck idle screw
    Hi Guys !
    Any tips on getting a stuck idle mixture screw loose (carbs still on bike) ?
    Of course it's the one under the octi but I jacked the tank up and moved the octi out of the way. Have a homemade screw driver to fit the slot and can get enough pressure that if I use any more muscle I'm afraid of ruining the slot.
    Thank You All ! Done };~)
    76 XS650 C ROADSTER
    80 XS650 G Special II
    https://ibb.co/album/icbGgF
    80 XS 1100 SG
    81 XS 1100LH/SH DARKHORSE
    https://tinyurl.com/k6nzvtw
    AKA; Don'e, UD, Unca Don'e
  • James England
    • 3039
    • North of England
    I would remove the carbs for that kind of thing.
    • donebysunday
      • Oct 2012
      • 1737
      • New Berlin, Wi.
      Stuck idle screw
      Hi James !
      I agree but the bike runs near ( as my perfect means ). I wanted to get er done. It's cold here 20°F, warm up to 40-50 for a day or 2 coming. All my solvents are not working for 3 days now.
      76 XS650 C ROADSTER
      80 XS 1100 SG
      • WMarshy
        • Apr 2009
        • 2402
        • Mexico NY
        Hi James !
        Why are you messing with it if your are satisfied with the way its running? I agree with James, take them off and get them on a bench. Might save you time down the road.
        '79 XS11 F
        Stock except K&N
        '79 XS11 SF
        Stock, no title.
        '84 Chevy K-10 "Big Blue"
        • ViperRon
          • Feb 2011
          • 1062
          • Woodstock, VA
          you might find a piece of rod about the same diameter as the pilot screw hole and put it in and tap lightly on the screw. You can not hit it hard or you will damage the head. Its basically the same effect an impact screwdriver used to break a stuck screw. I really do suggest that you take the carbs off to try fix it. It does not take as long to take them off where you can get to it easy as it does to fix what you may mess up doing it on the bike.
          Rodan
          1980 G Silverbird
          1198 Overbore kit
          Grizzly 660 ACCT
          Barnett Clutch Springs
          R1 Clutch Fiber Plates
          122.5 Main Jets
          ACCT Mod
          Mac 4-2 Flare Tips
          Antivibe Bar ends
          Rear trunk add-on
          • donebysunday
            • Oct 2012
            • 1737
            • New Berlin, Wi.
            perfection
            Was almost perfect, I want it as close to my perfect as I can get it.
            As it happened, I had a number of screwdrivers I made for on road adjustment and carb clean. Went through my bunch and found 1 that fit real tight in one of my collected idle mix screws ( funny only one screw had a nice slot in it, some were even off center ). With this added tight fit confidence I gave it another try, would not loosen but then it turned ever so slightly inwards, worked it to get the penetrating oil in the threads and I got it. All are now set at 3 turns out and ready to start but did not want to try in 20° temps.
            76 XS650 C ROADSTER
            80 XS 1100 SG
              Good to hear you got it out. Without removing the carbs gives you a built-in vise.
              Some time ago, I had to re-slot #4 idle mix screw with a tiny plunge bit and my dremal tool. Then I removed the carb bank, blew all excess brass filings out of recess and removed screw, squared top back off and finessed the slot perfectly with the dremal. That one ended up a bit more recessed, but all good.
              • donebysunday
                • Oct 2012
                • 1737
                • New Berlin, Wi.
                unstuck mix screw
                I've cut the towers, also opened them slightly with a chisel and used the dremel to just slice through the tower into the screw to make a slot for the screwdriver. What works ? Sometimes just discussing the situ gives one the heart to give it another go/rethink/inspiration.
                Thank You All !!!!! Done };~)
                76 XS650 C ROADSTER
                80 XS 1100 SG
                  • 3193
                  For one, I would have removed the carbs and done a very careful job of whatever attempt I was trying. trying to do it on the bike when the carbs can be off in less than 5 minutes is simply beyond me. The possibilities for problems are endless and every precaution should be taken to make sure you do not screw up. Trying to do it on the bike is just "So Wrong" to me.
                  Have you looked up the 5 minute carb removal and install threads?
