So, getting on the highway and I crack the throttle wide open, the bike catapults forward, but once it hits around 7k rpm, it shoots to almost redline with all engine noise rpms, and which does not seem like the power is going to the wheel yet, and then it seems like the engine catches up and the rpms fall back down to where the wheel is spinning at. Does this make sense?
A W.O.T. Question
A W.O.T. Question
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Tags: None -
Hey Ian,
It makes perfect sense....that your clutch plates are slipping....so when they break loose, the rpms rise but the bike doesn't go any faster....then they slowly reconnect/grip and the rpms come back down to match the actual speed! Get some HD Barnett Springs.....but adjust your clutch first at the engine!!!
T.C.T. C. Gresham
How nature points out the folly of men! -
Slipping clutch.
Have you put heavy duty spring in the clutch and (here we go again) what oil are you running?Greg
The list changes.Comment
Oh yeahand like TC said, check your adjustment.
I'd also take a look at the plates, both friction and steel ones. Remove any tarnish or deposits from the steel ones with very fine emery paper and check that they are not warped by laying them down on a flat surface and checking to see they are flat. The friction plates should also have a reasonable amount of friction material on them and no evidence of overheating or damage to the friction surfaces...a shiny, glazed appearance on the plates means you should give them some attention.
But, as TC said, check the adjustment first...at the engine end, then the handlebars. It may be too tight by a fraction. If not, new springs and a clean up of the plates will probably sort it out.....XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
There generally isn't any issue with the plates if the adjustment is right, the springs aren't weak, and the oil isn't full of additives that don't play well with wet clutches.
You REALLY have to smoke a wet clutch to damage THE PLATES.Greg
+1.....U will litterally have to see smoke coming off the clutch cover before questioning wet clutch disc wear.
That referance is more towards the moto-X world, which just means you were riding competitively and aggressive as you should be doing.
Maybe not quite to that extent on the street, but same idea prevails.
81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
Very interesting. I thought it was more a carb issue. Like, too much gas for the engine to combust.1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
The steel plates do get shiny with deposits though, I've found. I had bad clutch slip on the XS with nitrous and cleaning the steel plates and renewing the springs with 10% stronger ones cured it..XS1100F 1980 European model. Standard. Dyna coils. Iridium plugs. XS750 final drive (sometimes). Micron fork brace. Progressive front springs. Geezer regulator/rectifier. Stainless 4 into 2 exhaust. Auto CCT (Venturer 1300) SOLD. New project now on the go. 1980 European model.Comment
So, why does this only happen when I rip on the throttle wide open versus running it quick but not wide open? No other symptoms of a slip besides a false neutral.
Note: I am running Rotella T5 15w-40. Next Spring wil be Castrol 20w-50.1979 XS1100F
You generally won't notice it in 1st, 2nd, and maybe even 3rd but it will show up as the engine is working harder to accelerate at full power in the higher gears.
You still have the same horsepower but the rear wheel gets harder to turn.
I used Rotella in other bikes and it worked fine but the XS is a little more touchy that way. The clutch is actually too weak for the engine. Try running some different oil in it. 20W50 is what it needs but it can have no friction modifiers in it. The API sevice label should look like this
The bottom of the circle blank. Walmart house brand 20W50 works fine. I think it's called "Tech" or something like that.Last edited by BA80; 11-09-2013, 06:21 PM.Greg
Yeah, Super Tech. Blue bottle.1979 XS1100F
Yeah, that's the fella. Change the oil and filter and after about 50 miles or so the slipping should go away as long as everything else is good.
I do suggest strongly that you put some heavier Barnett springs in also. Night and day difference.
http://www.powersportsuperstore.com/Barnett-Clutch-Spring-Kit-501-58-06045-p/4143437.htm?Click=35177PowersportSuperstore.com is your first and best choice for everything aftermarket for the Powersports Industry. Buy, Smile, Ride, Repeat!Greg
The T5 has friction modifiers, and wet clutches don't play well when that is in the mix.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.Comment
oil?
Rotella T 15w-40 is JASO MA rated, has no friction modifiers(lower half of the API circle is blank). a gallon jug of it sells for about $20.00 most places. I find it works well in my '80 special, at least as well so far as the much more expensive "motorcycle specific" oils I've used. of course, ymmv.Comment
