For Those Whom Have Used Spraymax 2K . . .
    • 4015
    So, engine will be painted to match James' Black Beauty, using PJ1 satin black (I may go aluminum using Courtney's advice of Dupli Color) and gas tank, side covers, and seat cowl a custom color (Sunburst orange metallic [GM], or Mango tango metallic orange [Chrysler]). I want to use Spraymax paint, and I have some options. I could use their 1k, and then use the 2k high gloss clear, or just use the colored 2k, which does not require a clear. It worries me not using a clear. It would be under $50 to go this route. My other options would be to use someone elses mixed paint, and then go 2k clear. I worry about orange peel if I use a 2k color, as I'm used to wet sanding color prior to clear coating. This would be a new experience for me. Anybody go this route? Ideas? Not a typical paint thread.
    Why wouldn't you be able to wet sand the color?
      • 4015
      So, I'd wetsand the 2K color, and go straight to a polishing compound, then wax? If that's the case, that may be easier than doing a single stage with a 2K clear.
        Wet sand the color and then clear it like you would with any other paint.
          • 4015
          Ahh Mr. Moen, I may have typed that wrong. The 2K color does not need the clear, unlike the 1K base coat. See the reason for my question now?
            I know. It doesn't need it, but doesn't hurt. I don't know why you woildnt want to put a clear on it.
            Whichever version of the color you use you could wetsand it
              • 4015
              Personally, I would want to, but I assume whatever chemicals are used in the 2K clear, are already implemented in the 2K color, thus the elimination of needing a clear. I'd welcome Greg's input, as he has had issues with gas getting under this clear from the filler neck.
                All the more reason to do both in the 2k. It is really just the catalist/hardener that gives it the resistance. One person here used rustolium oil based enamal and brushed it on but mixed in the catalyst from an auto paint and it wored out fine.
                  I have been using just Dupli-color from Oreilly's for the color coat (because I'm a cheap a$$) and then the 2K clear over that. I believe that's why I've had trouble with fuel crawling under and bubbling the clear. Dupli-color is far from fuel resistant.
                  I think next time I will use the 2K for the color and the clear. I think the clear over the color even if the 2K is used for both will give the paint a deeper, more durable finish.
                  I just lightly sand the color coat to give the clear a good surface to adhere to. Don't worry about the orange peel (which is inevitable with a spray can) until the clear is on and has cured for about a week. Then, a good wet sanding with graduating grit down to at least 3000. I use 600 to knock down the orange peel, 1200 to smooth it then the 3000 to polish and a little rubbing compound to get a good shine.
                  Makes my arm tired just thinking about it.
                    • 4015
                    Nate & Greg, thank you for your patience and advice.
                      Another thing Ian, with your bike being a standard you could leave the filler neck unpainted and then just clear the bare metal to avoid the gas creeping under the paint.
                        Your welcome Ian.
                        I will correct my post though, I said 600, then 1200, then 3000. I meant to say (instead of 1200) 1500 - 2000. Sorry, it's early.
                          • 4015
                          Yeah, that's good advice Nate. I think that's how it is now. I'll go with both of your's advice, and clear the tank as well. It's soooo hard for me to change that paint because I like it so much.
                            On the Katana I recently completed, I used Duplicolor for the base coat, then I sprayed 2k clear over it. The clear really brought up the deep color and gave it a better shine. Obviously, the Duplicolor paint does not require a clear coat, but it certainly helps it achieve a deeper color and better shine IMO.
                            What I have read for the single stage paints says not to sand them, just use rubbing compound and buff them down. They tend to be thinner coats.
                              Dupli-color will melt and run with any contact with fuel. BTDT
