Turn signal troubles
    Originally posted by Punisher
    Thanks for all the information. It seems as though the possibilities are endless. I will continue cleaning connections in hopes of eliminating the problems. I did not consider the kill switch or the ignition. This will give me something to do this weekend.
    Hi Punisher,
    Mine rarely if ever flashes at idle.
    I am also constantly ( every year ) cleaning connections. The proper wattage of bulbs is a contributing factor. Kill switch just joined the items I will be checking next time.
      • 8062
      25 degrees F this morning. My turn signals flashed perfectly, even at idle with the brake lights on! My bike seems to like the cold better than I do.
      • Geezer
        • May 2003
        • 2985
        • Willamina, Oregon 97229
        I had to install a ground wire to both of my bar switches to get everything working properly. You can't always count on a good ground through the bars...
        Tony
