Engine work
  • Tat2demon
    • Jun 2012
    • 718
    • Sioux Falls, South Dakota
    Engine work
    Later this week Im going to start taking my E apart. The entire project will be a full dismantling of every single piece. Along with all the rebuilding of everything and all the powdercoating, I will be taking the engine apart to replace all the gaskets and seals.
    Is there anything else in the motor that I should be replacing while Im there? Was thinking I should have the cylinders honed and do rings at the time? It doesnt burn any oil but I really dont want to have to do this again in a few years.
    Nate
    78 XS11 "Matilda" 2H7 000364
    K+N Air Filter
    88 Voyager XII
    81 XJ650 Maxim
  • TomB
    • 967
    • Cumbria, UK
    If I had an engine that worked Ok and didn't burn oil I'd leave it well alone.
    If you want one to rebuild buy a fixer upper engine, that way if you're going inside its for good reason
    Just my 2p
    Tom
    • Tat2demon
      • Jun 2012
      • 718
      I would agree but I figured if it was going to be out of the bike already I may as well do everything I can. Im also going to do the Dremel fix on the tranny. It doesnt have any shifting problems yet but figured since Im there...
      Nate
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
        Face/palm....
        I'll throw in another 2 cents. If it ain't broke, don't fix it. Grinding perfectly good gears that don't need it is insane. Move the washer on 2nd gear and you'll be golden. Honing cylinders is done just to make rings seat. If you're pulling the cylinders off, then yes, you'll need a hone, but if you can paint what you need with the cylinders/pistons intact, don't pull them off.
        If you're splitting the cases, I'd freshen up the starter clutch and check for any copper color on your crank bearings. If there is only a touch and it's still mostly silver looking, leave them alone as well. Maybe a new cam chain if yours is anywhere near limits. Maybe freshen up your clutch springs.
        OK.. maybe that's like 8 cents.
        • Tat2demon
          • Jun 2012
          • 718
          Can the engines be powdercoated with everything in them? Wasnt sure how the gaskets and anything rubber inside would handle it.
          Nate
          K+N Air Filter
          88 Voyager XII
          81 XJ650 Maxim
            Never done Powder coat so I do not know the baking temp. Is it really that much hotter than the engine cases during operation on a good 90 degree day?
            As to the gears, if you have no sign of any slippage, then I would agree not to fix what is not broken. I would move the washer like Tod suggested and then look at the gears to see how rounded they look.
            • Pizzaboy
              • Jul 2013
              • 16
              • Oshkosh, Wisconsin
              If it aint broke dont fix it!!! I wish I would of been around to hear my advice a few times.....
              81 H Venturer
                Oshkosh Wisconsin, I flew into there once about twenty years ago. Now that was the airport, haircare, tire salon kind of airport. Two gates, the door on the left or the door on the right. Both just emptied onto the tarmac for you to walk over to the plane.
                  • 3917
                  Right thread Don?
                    Yes, I just noticed Pizza Boy is from Oshkosh.
                      Oshkosh airport is the site of possibly the largest Fly IN in the world.
                      Even I have heard of it
                        Not to completely side track the thread, but here is a map view of it.
                        OSHKOSH AIRPORT
                        All I know is, it was by far the smallest airport I have been to.
                          • 3917
                          Yeah, Wisconsin is definitely an interesting state. Down the road from my work is a small subdivision/airpark called Prince Field, where the house's attached garages are actually the plane hangars. I know airports are designated by class, and I believe it to be a "G", where-as Oshkosh one is probs a "D". There are many within the area of here that are smaller aurports including Oakland, Bishop, Reagan, Willow Run, etc.
                          • TomB
                            • 967
                            • Cumbria, UK
                            Too late
                            Tom
                            • Aches n Pains
                              • 349
                              • Reston, Va.
                              Nate,
                              On other thought. In my experience, powder coating is a bit thicker than high temp paint and can make an engine run a little hot. Fried an old Sportster once and think the powder coating contributed to my problems.
                              Aches n Pains
                              1995 KZ100P
                              Pods, jets, pipes, cam adjuster, oil cooler
                              1977 Ironhead - custom build
                              Hot engine, custom frame, KZ front and rear, high torque starter, alternator conversion, Progressive shocks, Thunderheart wiring, Dyna ignition, oil cooler, Dakota Digital instruments, etc.
                              Sold all my XS's to Eastcoaster but still love to keep up with you guys. This is the best cycle forum on the web.
