I recently did a plug chop to try to figure out what is causing the WOT miss between 4000-6500.
This is what the new plus looked like gapped at .32
Only 1 and 4 had any color on them
Here were the original plugs
They were all tan ish at the top of the insulator with maybe a tinge of yellow.
After that I tried fiddling with the ignition advance as I thought that I saw a hint of aluminum on some of the plugs I pulled but retarding the timing didn't solve the problem, however it did make it a little less noticeable. I also put on EMGO megaphone mufflers because I thought that my turnouts had no baffles and thus no backpressure. (Side note: Always check that dimensions of the parts prior to buying then so you do not have to mod them to make them fit.)
Today I rejetted from 145 to 142.5 since I thought that maybe I was a little too rich. Same problem, but a little less pronounced. Then I put in a gallon of 91 octane and it made it a little bit better and also made 6500-8000 pull really hard. I rode with the carb sync gauges on and at WOT I am pulling almost 0 vacuum with 16-18 in on full decel and 8 in on cruise.
I don't know if I have introduced too many variables but I am trying to do everything one change at a time, so that I am not shooting completely in the dark.
I SHOULD OF KEPT IT!!!
