Front wheels
  • tweeleft
    • May 2009
    • 110
    • Bend Oregon
    Front wheels
    Question is will the front wheel of a Special fit on a Standard? And would I have to change the brake rotors?
    Keep the shiny side up
    1979 XS1100SF
    Mac 4-1
    Drilled airbox Uni filter
    Vmax bars
    Virago 1" shorter shocks
    30K miles
    http://i1228.photobucket.com/albums/...429_135845.jpg
    1981XS1100SH
    '80 G Forks and Triple Tree
    '80 G tank
    Mac Turnouts
    Virago 1" shorter rear shocks
    SH Headlight
    http://i1228.photobucket.com/albums/...psd6adaae1.jpg
    61 Wife
    83 Son
    86 Son
    89 Daughter
    • 9980
    Yes, they are direct fit. 78 and some 79 standards had tube type rims though.
      • 8054
      No, you don't have to swap the brake rotors.
        IIRC, you could also use the front wheels off of an XS750/850, or XS650.
          • 8054
          For the XS750/850, you do need to swap the rotors. XS650's are single rotor, but the same as XS1100.
            • 9980
            I believe the 650 is different, not certain about the 750 but I know the 850 front and rear will work if you change the rotors.
              • 8054
              XS650 wheel is a match for the XS11. The SR500 front wheel is a match, too! The XS650 is the only one I'm sure has matching brake rotors.
              • SFerinTEXAS
                • Jun 2006
                • 877
                The speedo parts are not the same as I recall.
                79SF
                XJ11
                78E
                • tweeleft
                  • May 2009
                  • 110
                  • Bend Oregon
                  Thx. Going to install 80H forks,brakes and fender on 81SH with the SH wheel. I knew about the speedo parts and have all of the above.
                  1979 XS1100SF
                  Mac 4-1
                  Vmax bars
                  30K miles
                  1981XS1100SH
                  '80 G tank
                  Mac Turnouts
                  SH Headlight
                  61 Wife
                  83 Son
                  86 Son
                  89 Daughter
                    You will want to swap the triple trees as well if you swap forks between the Standard and the Special models. Swapping only one of the two changes the trail of the steering and can / will effect handling. And not to be nitpicky, but the 80 models are G models. The letter E, F, G and H refer to the model years 78, 79, 80, and 81 respectively. The S was added for Specials, and an L was added for the Midnight Specials.
