"80 Special "octy" question
  • 650mark
    • Jul 2012
    • 307
    • Mesa, Az.
    2 of the hoses coming from the "octy" to the petcocks supply fuel but why the 2 "vacuum" hoses also going to the petcocks? what do they do? thanks
    There are 2 fuel lines on each of the special petcocks. Only 1 vacuum line, and that goes to the octy.
      If you have vacuum hoses going to the petcocks you either have a standard tank on there or you have vacuum lines hooked to fuel outlets. On the special petcocks there is an regular outlet at the rear and a prime outlet on the front on each side. They are both the same size.
      How about a picture of what your talking about?
      • 650mark
        • Jul 2012
        • 307
        • Mesa, Az.
        you just answered my question. both of my petcocks have on, off, reserve, and prime. now I understand that those other 2 hoses provide fuel when in prime position. now I get it. thanks.
          • 650mark
            • Jul 2012
            • 307
            • Mesa, Az.
            thanks again for the info and the diagram of the fuel hoses. i'd like to buy a spare rubber vacuum valve inside my octy assembly but I can't find a part number anywhere. partzilla shows only the complete assembly. any clues? thanks
              If you get a petcock rebuild kit for the specials it usually comes with the octy diaphragm as well.
                http://www.ebay.com/itm/Fuel-Petcock...022128&vxp=mtr
                • 650mark
                  • Jul 2012
                  • 307
                  • Mesa, Az.
                  thanks again for the help
                    Keep in mind that a leaking vacuum fuel valve is usually caused by a bad seat or o'ring. Make sure you get that seat smooth as a baby's bottom.
