Putting bike back together, measuring shim gaps for good measure, ran into huge gaps.
  • ff255away
    • May 2013
    • 13
    • Everett, WA
    I had E2 and E3 valves replaced, and am in the process of putting everything back together. Considering I was not sure how much the gaps had changed, I went through and remeasured everything.
    Measurements were as follows:
    E1- .23 E2- .25 E3- .24 E4- .32 (new bucket)
    I1- .73 I2- .86 I3- .80 I4- .88
    I've done nothing to the intake side. Any ideas what could possibly have happened? I'd like to replace all of the nuts holding the cam shaft in place, several of them were stripping. But I didn't think that would account for gaps four times as large as intended.
    80 LG
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    Gaps that large would suggest that the valves aren't seating all the way.
    Since you had the valves replaced did you check the valve seats to make sure that you got 100% around the circumference seating?
    Were the 'new' valves straight and not slightly bent?
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    • ff255away
      • May 2013
      • 13
      • Everett, WA
      How would the exhaust valves interact with the intake valves? As far as I know, the new valves were totally fine- neither of them have irregular gaps and no leaks.
      80 LG
      • GLoweVA
        • Jun 2011
        • 1957
        Not knowing how you put your cams back, but if done improperly yoir intakes could come into contact with the exhausts and possibly bend one or two.
        Another possibility is some had put cams in with the head on a bench and bent valves that way.
        It is entirely possible that all is good and you'll need some of the larger shims. I think the largest ones I've seen are around 305, 310.
        The Green Monster
        Got him in '04.
        Scarlet
        Got her in '11
        Hugo
        Cold weather ride
        • GLoweVA
          • Jun 2011
          • 1957
          Another thought is make sure you've got the right cams in the right spots.
          I know it sounds stupid, i've done it and luckily i caught it before i had all the cam caps torqued.
          The Green Monster
          Got him in '04.
          Scarlet
          Got her in '11
          Hugo
          Cold weather ride
            Huge gaps like that usually go along with bent valves.....
            Might have to pull the head and see what's up.
            ฮผฮฟฮปแฝผฮฝ ฮปฮฑฮฒฮญ
            • WMarshy
              • Apr 2009
              • 2402
              • Mexico NY
              I agree with everyone else, the intake clearance is extreme. You've got problems on hand. Did you do all the work yourself?
              As noted previously, you can have valve to valve interference if both are open at the same time. In addition, setting the head flat on the bench with the valve open will bend them. Quick easy check for bent valves is turn the head over (valve side up) and choose a chamber with both valve closed and fill the dome with some water. Good luck.
              '79 XS11 F
              Stock except K&N
              '79 XS11 SF
              Stock, no title.
              '84 Chevy K-10 "Big Blue"
                • 3917
                Yeah, curious myself as to whether u did the work yourself. I took mine to a machine shop, and had all valves installed, seats ground, lash set for cheap. All I did was drop the head on and go.
                • MPittma100
                  • Aug 2011
                  • 2359
                  Correct Repair
                  +1 on that. Your machine shop should be able to return your head to you ready to bolt on - lashes set, valves ground, cams installed, and all cleaned up - READY! Make sure that they can do that before you leave it with them. If they are unable to repair the head in this fashion, go elsewhere.
                  Mike
                  1981 XS1100H Venturer
                  K&N Air Filter
                  ACCT
                  Custom Paint by Deitz
                  Geezer Rectifier/Regulator
                  Stebel Nautilus Horn
                  EBC Front Rotors
                  Limie Accent Moves On In 2015
                  Mike
                    • 3917
                    The only I asked them not to do was torque the cam caps, as I wanted to remove cams to slip chain around the sprockets, instead of breaking the chain. Good thing, as they installed the cam caps in reverse order.
                      ??? Reverse order? Ex on the intake? or # 1 where the # 5 goes.
                        • 3917
                        #1 where the number five goes.
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          Ian, How'd they check the valve clearances without torquing down the caps?
                          The Green Monster
                          Got him in '04.
                          Scarlet
                          Got her in '11
                          Hugo
                          Cold weather ride
                            • 3917
                            Good question! It was on my list to verify the valve lash was within spec, but never did. My bad. I do intend on checking them over the winter when I paint the engine.
                            • ff255away
                              • May 2013
                              • 13
                              • Everett, WA
                              All 4 valves are bent. I had the exhaust valves professionally replaced, so that means I must have screwed up the timing pretty bad when I set everything back together. I'll be taking it into a shop to get the four intake valves replaced.
                              Can anybody recommend a shop north of Seattle? And a fair estimate to replace all four intake valves? The guy who did my two exhaust valves charged 50 dollars a valve, and I provided the parts.
                              80 LG
