Are the frames different between a special and a standard?
  • tweeleft
    • May 2009
    • 110
    • Bend Oregon
    I guess I'm asking if there are issues putting standard forks on a special. Install and handling. 80g to a 81sh. 81 needs brakes and fork seals. 80's are both good.
    Keep the shiny side up
    1979 XS1100SF
    Mac 4-1
    Drilled airbox Uni filter
    Vmax bars
    Virago 1" shorter shocks
    30K miles
    http://i1228.photobucket.com/albums/...429_135845.jpg
    1981XS1100SH
    '80 G Forks and Triple Tree
    '80 G tank
    Mac Turnouts
    Virago 1" shorter rear shocks
    SH Headlight
    http://i1228.photobucket.com/albums/...psd6adaae1.jpg
    61 Wife
    83 Son
    86 Son
    89 Daughter
  • tweeleft
    • May 2009
    • 110
    • Bend Oregon
    Is the rake different as to the handling?
    1979 XS1100SF
    Mac 4-1
    Vmax bars
    30K miles
    1981XS1100SH
    '80 G tank
    Mac Turnouts
    SH Headlight
    61 Wife
    83 Son
    86 Son
    89 Daughter
      The steering neck is the same on the Standard and Special frames, the forks and triple trees are different as well as the calipers. If you change the triple trees along with the forks, the rake/trail will remain correct.
        I know you didm't ask, but you better get the fender also.
        • tweeleft
          • May 2009
          • 110
          • Bend Oregon
          Thx. I have the 80 as a parts bike. Using tank and other parts
          1979 XS1100SF
          Mac 4-1
          Vmax bars
          30K miles
          1981XS1100SH
          '80 G tank
          Mac Turnouts
          SH Headlight
          61 Wife
          83 Son
          86 Son
          89 Daughter
            Changing brakes and fork seals is much less work than changing the entire front end.
            Just sayin'
            • Eveready1100
              • 539
              Tweeleft, I did the swap a couple of years ago, due to being left seal-less by a narrow minded dealer over here.
              [IMG][/IMG]
              I left the trees alone, as that would've also meant swapping the headlight ears over as well. Just swapped over the forks, brakes, front guard, and speedo drive. Did about 50,000 klms till I got around to refitting the stock bits, which included towing my trailer on a couple of trips.
              Had no problems with the slightly different steering at all, and also benefitted from much better braking from the standards calipers??
              I'd say if you've got the bits on hand to get the job done, go for it.
                Originally posted by Eveready1100
                - - - Had no problems with the slightly different steering at all, - - -
                Hi Errol,
                "slightly different steering" you say?
                With ~2" extra steering trail?
                Jeez! How much do you bench press?
                BTW, that's a very pretty bike you have there.
                • TomB
                  • 967
                  • Cumbria, UK
                  Hi Errol,
                  I run with the same set up as Errol and find it Ok, I do have 32" bars which probably accounts for why I find it Ok.
                  Tom
                  • Eveready1100
                    • 539
                    Fred, can't say how much I can press, as I've never been near one, and for the record, I'm 5'9" @ 149lbs so I'm not exactly built like a gorilla.
                    Plus those RH bars are about an inch narrower than the euro standard bars
                    As far as steering the bike goes, it was really only slightly different to turn in to the turns, as compared to with the stock setup. Handled my favourite sets of twisties with ease, but my biggest thing that changed on the bike was the brakes. Kept the original 5/8" master cylinder and only swapped the calipers over but the change in braking force was phenomenal. Even with the original spongy lines, I could lock the front wheel if I wanted.
                    So different that when I put the original front end back on, it scared be badly and was quickly updated with braided lines and sintered pads just to get them working with any sort of parity to the Standard ones.
                    • TomB
                      • 967
                      • Cumbria, UK
                      I'm also with you on the brakes Errol, I use standard 2H9/2H7 calipers that should use the 11/16" M/C with my 5K7 5/8" M/C and found the brakes great, much better than with the 11/16" M/C. I can lock these brakes.
                      More lever travel because of it but if bled up with new fluid not excessive
                      Tom
