Had to pull over on the highway 3 times today.... :(
    So, did you try running the bike on prime?
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      When it started to sputter and feel like it was loosing cylinders...yeah, I would try reserve first, then prime.
      No change
      Then when I got to where I was going( it did it right before my destination) I let it sit for a work shift...
      Started it up and it was STILL doing it.
      So I gimped it to the fuel station, and it was fine.
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
      • TomB
        • 967
        • Cumbria, UK
        Originally posted by sparkfly88
        So, I think its a fuel level issue...
        So, it seems to only pitch a fit when Im a little lower on fuel
        You may have something there. A full tank gives a greater head, if you have kinked fuel pipe or other partial blockage a greater head of fuel will push through more fuel compared to a low fuel tank.
        Tom
        • Stoners420time
          • Oct 2013
          • 30
          • Niagra Falls, New York
          I had some problems like your speaking of, my fix was to replace the fuel line's with car brake line's, tight bends but it does not look bad and it run's great at all speed's. good luck tho.
          79 XS 1100 SF, Niagara Falls, New York 14305
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            Okay, so today I changed out the lines and filters.
            Now then, when I had the tank off, I checked all operations of the petcocks.
            Sucked on the vac line, fuel comes pouring out on both sides, in all modes, at the same flow rate.
            Ditto with the prime on both.
            SO, I put the new lines, and new filters on.
            Put tank up on bike, installed lines to carbs.
            Flipped to prime.
            Started bike.
            One filter filled INSTANTLY almost completely filling it.
            The other, barely did, maybe a third of it filled, just enough to contact filter media.
            I took the bike for a ride down the road, and came back.
            Filters were at the same levels.
            SO...
            What gives
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
              Maybe the floats for those two bowls were already full which cuts off fuel from the line. You rode the bike, dropped the floats and the air was flushed out...
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                Sorry, i mean the filters were at the same levels...meaning they didnt move.
                One was still full, the other barely had any in it
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                  PS, this does not apply to you if you had problems previously in the prime position, but I have an xs11 (standard) that has occasional issues with fuel starvation at about 60 mph and I have to switch the left petcock to prime to alleviate the problem. I am guessing that the spring is a little too stout for the diaphragm in the petcock (yes I stretched it a little once when I rebuilt the petcock). With mercury sticks you can see that columns of Hg drop some when the throttle is open and constant...at least on my bike. That could cause the vacuum operation for fuel flow to malfunction.
                    Hey Spark,
                    Are the filters on their side or vertical? Having some air in the filter doesn't mean that it isn't flowing fuel. The filter doesn't slow down the fuel flow, and sometimes once the fuel gets to the outlet, it can just flow THRU the filter without necessarily filling UP the filter chamber.
                    You can test it by just pulling the line downstream from the filter and open the line and see how much/fast the fuel flows from the hose, you'll probably find that it flows just as fast as the other side.
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      Well, I rode to work and back today.
                      Then adjusted my idle which was too high and colortuned it.
                      After all of this, I look at the filters, and they have basically matched each other.
                      I'm at 51 miles for this tank. Let's see if around 80 it has a fit about the fuel level again.
                      And yes topcat, they are sideways.
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                      • sparkfly88
                        • Mar 2013
                        • 585
                        • CedarKey FL
                        Well, I passed 80 miles with no incident.
                        See how long this lasts.
                        79F
                        "Excelsior"
                        Hid headlight 6000k
                        Stock jets
                        Shinko 712 F & R
                        TC fuse block
                        Raptor 660 Acct
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          So returning to this problem...
                          Yesterday at 96 miles my bike started bogging down again...I think on 2 cylinders....I'd turn it to reserve, or prime and no change would happen.
                          So I gimped it to the fuel station and pumped 3.66 gallons into it. ( right up to the neck till it bubbles )
                          That put me at 26.9 mpg for that tank driving to and from work around town and one highway trip of 10 miles or so.
                          Now it seems I'm missing a cylinder at low rpm...
                          I have the feeling my fuel saga yesterday caused a float to get stuck. I hit my carbs with a rubber mallet but no change.
                          Both fuel filters are filled to the brim which is nice.
                          Time to go in AGAIN
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                          • sparkfly88
                            • Mar 2013
                            • 585
                            • CedarKey FL
                            Tomorrow I'm gonna a pull it into one of my bays at work and tear it down yet again.
                            I got home today and figured out it is my number 2 cylinder this time.
                            Pain in my neck!
                            79F
                            "Excelsior"
                            Hid headlight 6000k
                            Stock jets
                            Shinko 712 F & R
                            TC fuse block
                            Raptor 660 Acct
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              Well I disassembled my bike, AGAIN and went through the carbs AGAIN
                              I didn't see anything out of the ordinary...gave em a good blow out with parts cleaner and high pressure air at the shop.
                              Reset all my floats to a more accurate level, which looks WAY better than what I had before.
                              Synced, colortuned, synced.
                              Purrs like a kittin on crack
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
                              • Pizzaboy
                                • Jul 2013
                                • 16
                                • Oshkosh, Wisconsin
                                Is it possible, you have the broken wire coming out of your pick up coil on the left side of the engine? Are you absolutely sure its a fuel problem and not an ignition problem? Just my thoughts as I was reading your misfortune.
                                81 H Venturer
