My morgan carbtune came yesterday so synching carbs was the goal tonight. My XJ has stock jets, exhaust, and air box. Also has YICS eliminator tool installed. Carbtune has the restrictors in the 4 tubes about 4" from the carbs.
Bike starts easily, warmed it up with fan blowing on it, and set idle at 1100 with screw below carbs. I was able to synch 1 with 2 but then their levels on the carbtune would change a bit while I was synching 3 and 4. Kept going side to side and what ever pair I synched would move while I worked on the other pair. The idle would keep changing also. And if I blipped the throttle, the rpm's would slowly come back to around 1100 but it took a few seconds to get there. My mixture screws started at 2.5 turns out (have new o-rings in there so I have some difficulty "feeling" when they are lightly seated), but turning them in or out as much as 2 full turns had little effect on the rods in the carbtune as I try to see the vacuum increase. I guess I thought I would see big changes on the carbtune as I turned screws, but the biggest thing that changes seems to be the idle speed...am I doing something wrong?
How do I keep the idle speed constant? And what is the adjustment on the throttle up near the grip used for? How much so I have to turn the mixture screws to see a vacuum increase? Is it normal for the levels on the carbtune to keep changing or should they stay pretty steady once I stop adjusting?
Thanks in advance for the tips and guidance.
