repainting XJ11 side panels - Side panel question
  • KA1J
    • 664
    • Groton, CT
    I have the tank prepped to paint but I can't figure out what is the easiest proper way to remove the center painted triangle in the side panels and then to remove the badge "Maxim" from that inner panel so I can paint those panels too & then re-assemble to put back together.
    Once I get that done, how do you re-attach the painted part back onto its aluminum frame & then how to attach the badge "Maxim"?
    If there's a known answer I'd rather do that than guess and make a mess of things.
    Gary
    The plastic inserts are held on with trim clips, you have to pry them off carefully.... You can get replacement clips at most any well-stocked hardware store, so if any break don't sweat it. To reinstall, just press the clips on.
    The emblem is attached with two-sided tape. You find that at some auto parts stores, for sure at a auto body supply, but you may have to buy a full roll.
    • KA1J
      • 664
      • Groton, CT
      Thanks Steve, great info. I'll do just that.
      Gary
        Hi Gary,
        Use some fishing line or dental floss to "slice' off the emblem held with tape. I recommend 3M brand tape, if you can find it, for reattaching.
        Will cost more $$$ AND will work. as a life long member in good standing of Cheap Bastards this is a heart felt suggestion.
