HI all,
I need a bit of advice regarding valve clearance adjustment on my 1980 XS1100.This job is taking a while as I have a lot of other commitments and it's been several months on the go.I finally got the new pistons fitted and the head bolted down,cams in and everything lined up nicely.
Now to the problem.I fitted four new inlet valves after having the guides replaced and the valve seats matched to the new valves.
I began checking the existing clearances prior to reshimming.The exhaust clearances were simple to check but when I came to checking the inlet clearances I cannot get even a 0.04mm feeler guage in let alone a 0.16mm.In effect I have no useful clearance at all.
I have ideas why this might be but am a bit unsure how to solve the problem.
I'm guessing that the fact the enginneer cut the seats after putting in the new guides has raised the valves a bit higher.Any suggestions will be appreciated.
Thanks
xssidecar
Thanks
xssidecar
	 ) coming out is very difficult to do when running engines at normal engine operating speeds, and if you do have one come out you'd be extremely unlucky to wreck any more than the head/valves, and the alternative for XSsidecar is a new head anyway.
