Installing New Exhaust Studs
  • D0wn5h1ft
    • Aug 2013
    • 515
    • Westerly, RI.
    With my '79 build finally underway (thanks to IanDMacDonald for some much needed parts) I figured I'd seek out some suggestions to not repeat some of my past mistakes. The '79 has a few missing (not broken off) exhaust studs that I just ordered from my Yammy dealer that should be in by the end of the week. Problem is, last time I tried installing a new exhaust stud (on the '78) it broke off in the head and I had to do the ol' "tig weld a nut onto the snapped off stud" trick to get it out.
    I usually have a pretty good hand at estimating torque but apparently not that time. To drive the stud in I actually had to use a small cheater bar because even though it wasn't even close to being in all the way it was taking well over 14.5 ft-lbs to drive it in. Is there some special trick to making these studs go in easier? Because last time it was going pretty well until I bottomed out the stud and broke it off . Any tips would be appreciated.
    Having recently had a broken stud I too am interested in any others experience.
      • 4015
      I believe those are M8 studs. You could get a tap and coat it with grease (catch any shavings), and then chase the threads in the head. Also, coat the studs in some type of lubricant prior to install.
        Yup, I too would run a bottoming tap into the hole first and clean it all up as much as possible before hand and then try.
        Measure the depth of the hole as well and then mark it on the stud so you can see where you need to stop.
          A thread chaser would actually be preferable to a tap.
            • 4015
            Ahh, I did not know there was a difference. I just googled that. Good to know for the future.
              Taps cut threads, thread chaser pushes damaged threads back into place if possible.
              • D0wn5h1ft
                • Aug 2013
                • 515
                • Westerly, RI.
                Couldn't find a thread chaser at the local hardware store so I picked up a 8mm (1.25) tap and wrench and it worked like a charm. Is there any reason I should need to put a high temp thread locker in? Or will the initial heating/cooling lock it in place during start up?
                • Cobia
                  • Jul 2007
                  • 1587
                  • Palm Beach County, Fl
                  Instead of tread lock I would apply a never seize type product. There are some very good ones at marine supply stores although not cheap, but you can use them for just about everything you're putting together and may want to replace eventually.
                  1980G Standard, Restored
                  Kerker 4 - 1
                  850 Rear End Mod
                  Automatic CCT
                  1980GH Special, Restored
                  '82 XJ1100 (Sold)
                  • Gallaecus
                    • May 2011
                    • 254
                    • East Haven Connecticut
                    I think taps are tapered so it may not cut sufficiently at the tip.
                    go for the anti seize.
                    throw your easy outs in the trash.
                    a steel bolt and some wd40 vs your aluminum block will work too, but if the tap worked, great.
                    Steven
                    1981 XS 1100 LH
                    1979 XS 1100 SF
                      That's why you need a bottoming tap. It cuts nearly to the end and has a flat blunt tip rather than the tapered pointy tip of other taps.
                      • CaptonZap
                        • Jun 2010
                        • 1748
                        • Denver
                        Under emergency circumstances, a plug or taper tap can have the tip ground back to make an ersatz bottoming tap. Your local Ace Hardware will probably not have all three styles of taps in the metric size you need.
                        Necessity is a mother!
                        CZ
