MPG & What octane gas do you use? - Take 2
  • XS11UFO
    • May 2012
    • 74
    • Palatka, Fla.
    #46
    Just Dec. and Jan. sometimes Feb.
    Scott
    1978 R100S BMW
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      #47
      Riding to work here are my averages...pretty piss poor...
      10 most recent fillups recorded
      27.435 mpg average
      3.16 gallons per fillup
      91.73 miles per fillup
      5 days per fill
      31.64 gallons total used
      $107.58 total used
      $ 0.125 per mile
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
        That looks like my fuel consumption.
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          #49
          Carbs are rebuilt, and set to where I think they need to be, synced, colortuned...
          Even my valves are set..
          Dont know why my mileage blows
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
            • 1591
            27.435 mpg average
            Is that 27mpg from stop & go uglies on local stuff Tamiami Trail / Fruitville Rd etc. -or- blasting at high revs back & forth on I-75?
            • sparkfly88
              • Mar 2013
              • 585
              • CedarKey FL
              #51
              Primarily on Beeridge from cattlemen to 41.
              A couple blasts here and there on the highway.
              79F
              "Excelsior"
              Hid headlight 6000k
              Stock jets
              Shinko 712 F & R
              TC fuse block
              Raptor 660 Acct
                • 1591
                MPG Test
                Had an opportunity to do a little unscientific MPG testing on a 275 mile ride yesterday. Results were not surprising, but interesting (at least to me). Ride was not the usual mountain near WOT ripper, but somewhat of a spirited rolling hills country ride.
                1. Rode an hour on the interstate (I-85) holding right at 4,900 rpm. That's 75 mph on my 11E. Filled up by the On Ramp (Shell 87 EPA mandated Metro blend) and Topped Off at the Off Ramp (Flying J 87). Got 35.3 mpg for that run.
                2. Next was some slower local highway stuff. Rode the next hour at 3,500rpm to 3,600 rpm. Topped off that tank (Marathon 87) getting 44.6mpg on that run.
                3. Next hour was a very steady at 3,900 rpm which btw gets me 60 mph. That run was 40.9 mpg and topped off again (Raceway 87).
                4. Final run was a mix of narrow country back roads and some two lane highway. A lot of stop signs but rarely got up over 55 mph and a lot was 35-40 mph. So that run was back in the +-3,500 rpm range for an hour or so. After another fillup-topoff I got 43.4mpg. The average for the day was a fairly respectable 41.5mpg on the 87 octane stuff. Guess the moral of the story is (at least for my 11E) that the mpg's ain't bad running up to 60-65mph or maybe 70mph, but as the RPM's increase from say 4,000rpm to 5,000rpm or more the mpg drops like a rock. To complete the test a bit more accurately I needed a good run at steady 5,500rpm to see how much the mpg's drop off between 5,000rpm and 5,500rpm. Beyond that I'd don't need to know since I don't have any road trips planned with Tod, Harry, Greg & John.
                Conditions: Tire(s) pressure @ 40psi, brakes not dragging, tires only hitting the pavement, greased wheel bearings, Royal Purple 75W-140 in Mid & FD, Yama20W-50 in motor, 67 degrees, 180lbs of me+stuff, 800ft elev, calm winds, fairing+bags on, rider smiling (a lot).
                At the SE Rally I was getting about 39mpg riding in the mountains with only a little of the steady high rpm freeway stuff. Since I usually ride in the mountains and get 37-38-39mpg it is surprising to get something above 40-41. In any case, a pretty day and a fun ride ..............
                  That's part of my mileage issue. At 75 mph, I'm turning 5,500 rpm.
                    That's the difference between the 17" wheel on the Standard and the 16" wheel on the special. With the FD conversion on the Special the RPMs are exactly the same as the Standard.
                      RPM's are my friend. ZOOM, ZOOM!
                        After 1st gear it really doesn't make a difference. You've ridden with me before Marty, my SG has the conversion. You just need to run in 1 gear lower than you did with the stock FD and on the highway you have "OVERDRIVE"
                        • MPittma100
                          • Aug 2011
                          • 2359
                          Mpg
                          I find that I get my best gas mileage when I am behind a Hogsley Ferguson - about 3 more MPG than normal. LOL
                          Mike
                          1981 XS1100H Venturer
                          K&N Air Filter
                          ACCT
                          Custom Paint by Deitz
                          Geezer Rectifier/Regulator
                          Stebel Nautilus Horn
                          EBC Front Rotors
                          Limie Accent Moves On In 2015
                          Mike
                          • MPittma100
                            • Aug 2011
                            • 2359
                            Mpg
                            Greg, what MPG do you get with the 750/850 FD compared to the OEM FD?
                            K&N Air Filter
                            ACCT
                            EBC Front Rotors
                            Mike
                              #59
                              Mike
                              Hi Mike,
                              drafting, eh? being sucked along by a Hogliegh Poodleson with a fat guy riding it?
                              You'll get better mileage yet if you draft behind a semi but be careful, a semi got better brakes than a H-D.
                              • jwhughes3
                                • 2798
                                • Home of the Alamo
                                #60
                                Mike
                                Mike I think your decreased fuel consumption is less dependent on the draft and more dependent on the stately speed with which most HDs run
                                John
                                '81 XS1100H - "Enterprise"
