If they had a heli-coil installed, you may be able to reinstall one, using some good lock-tite with it and try that.
Trouble Trouble Trouble
78 XS750 -
Motorcycle Classics covered stripped spark plugs in their magazine a while ago. Have a look.
Spark Plug Rethread
XS650EComment
Stripped plug
I had a similar problem with stripped plug awhile back.
I was away from the house when it let go!
All I heard was a pop and a loss of power.
I frequent a GREAT Yamaha shop here that repaired it on the bike.
I'm sure someone will frown at that but these guys are magicians.
True enthusiasts not a bunch of monkeys turning wrenches.
It doesn't hurt that I have done business there for 37 yrs.
Good luck78standard,79 & 80 Specials; 2 x 650 Maxims; 4 x RD350's; yz450; 2 x Honda tlr's;2x jt1 mini.Comment
Great post Marty!1979 XS1100F
2H9 Mod, Truck-Lite LED Headlight, TECHNA-FIT S/S Brake Lines, Rear Air Shocks, TKAT Fork Brace, Dyna DC-I Coils, TC Fuse Block, Barnett HD Clutch Springs, Superbike Handlebars, V-Star 650 ACCT, NGK Irridium Plugs, OEM Exhaust. CNC-Cut 2nd Gear Dogs; Ported/Milled Head; Modded Airbox: 8x8 Wix Panel Filter; #137.5 Main Jet, Viper Yellow Paint, Michelin Pilot Activ F/R, Interstate AGM Battery, 14MM MC, Maier Fairing, Cree LED Fog Lights.Comment
It isn''t just about over-tightening. The steel plugs and aluminum head are "dissimilar metals" which tend to cause something like a chemical weld. I use a little Never Sieze on the threads every time the plugs are reinstalled.Skids (Sid Hansen)
Thanks for the info! it worked the hole was in real bad shape the last coil they put in was not at the right angle so it was a huge pain to get it to a point were it will work. the next time there is an issue its going to involve replacing the head. but until thenMotorcycle Classics covered stripped spark plugs in their magazine a while ago. Have a look.
Spark Plug Rethread
ITS ALIVE!Comment
Remember too that the crush washer on a sparkplug is an important part of preventing over-tightening. When you install a new plug, you hand tighten it to the contact point, then turn it just a half-turn more. Take that plug out, put it back in like when it was new, and that 'half turn' more crushes the washer more again. Do that a few times and there's not much 'crush' left in the washer. I'm not saying to replace the plug after "X" installs, but pay close attention when you're tightening that half-turn more on an experienced plug.Ken TalbotComment
If you read the instructions on the box the pugs come in it will tell you IIRC 1/8 turn past seated once the plug has been installed previously. That is important.Last edited by WMarshy; 10-19-2013, 06:43 PM.'79 XS11 F
Stock except K&N
'79 XS11 SF
Stock, no title.
'84 Chevy K-10 "Big Blue"
"What they do have is an implacable, unrelenting presence and movement that bespeaks massive power lurking behind paint and chrome. They don't wail like a screeching ninja, the don't rumble like a harley. They just growl like a spactic, stressed out badger waiting to rip your face off and eat your soul." Trainzz~RIP~Comment
A torque wrench is always a good option for plug installation. Using one at least a few times should give you a feel for it. On a pre-owned vehicle such as this one, there seems to be no shortage of fasteners installed by a gorilla (over torqued).Marty (in Mississippi)
XS650EComment
