So I'm having a bit of a problem. I changed out my 4 to 1 exhaust for a 4-2 exhaust and I'm having some bogging down issues. I have never tuned carbs before and I was wondering what might be my issue. If I'm sitting in 4th gear around ~2500 rpms and I open up the throttle a lot I notice a huge lack of power and the engine sounds like it's struggling. I had this issue a bit with the 4 to 1 exhaust but it has gotten significantly worse with the new exhaust. I guess I have a few questions [yes the butterflies have been bench synced] [Also, I have pod filters on]:
-Does a new exhaust require carb tuning? (I assume yes)
-If I have to tune my carb, where should I start? Should I start with the idle screws? And would the idle screw mixture be the main issue with this lack of power I'm noticing?
-I noticed the #3 spark plug is a light grey color, does that mean it's running too lean? And if so how do I fix it?
-Do I really need to get new jets or is there some tuning I can do to see if the ones I have will work?
-Which jets do you think I would need to change out if any? (Mains, Pilot, etc)
I think the float levels are fine because my high end power is great (>5k rpm). The jets aren't clogged because I just triple cleaned the carb. I guess I just need some help on where to start. I have read the guides on here but I'm not really sure which ones apply to the issues I'm having.
