jardine exhaust question
  • graybird78
    • Apr 2003
    • 360
    • council bluffs iowa
    so i got a jardine 4-2 with no cross over from buckmaster79.i already have dyna coils,and uni air filter installed. will i have any jetting issues with this set up. my god is it loud bike runs good.i know it will need valves adjusted and timing chain adjusted.ride home tonite bike pulled excellent through all gears.just want to be cautious.
    when you want something bad enough, don't let anything stand in your way, and don't take "no" for an answer. EVER
    graybird78
    80 sg (old faithfull)
  • graybird78
    • Apr 2003
    • 360
    forgot what to do for bump stops for kick stand and center stand. no provisions on exhaust, like on factory exhaust
    graybird78
    • dpotter58
      • Aug 2004
      • 1844
      • Southern Maryland
      Be careful on the right hand turns. That exhaust hangs low...
      1980 LG
      1981 LH
        Hey there Graybird,
        I ran my stock 81Sh with a Mac 4-1 for 9 years without increased jetting, it had the OEM airbox and filter then. I did seem like it was a little weak in 5th when trying to push it too high, but otherwise had plenty of power to redline in the other gears. With your pipes sounding LOUD suggests that they may not have any actual baffles in the mufflers??
        You've got strong hot spark, and so the concern would be running too lean/hot and burning holes in your pistons. I forgot to look at what year you have, Yamaha jetted them leaner in the later years for emissions.
        Folks will probably suggest watching your plugs closely, and if they are bleach white.....then you could probably go up 1 or 2 main jet sizes, and recheck your plugs.
        • graybird78
          • Apr 2003
          • 360
          did forget to ask here if anyone knew if the jardine mufflers were repackable..last time i was in the carbs it was stock jetting.engine is at 45k.
          graybird78
            ........believe that was 4into2, not 4into1 referred to....
            • dpotter58
              • Aug 2004
              • 1844
              • Southern Maryland
              i really need to put on my glasses when I read
              1980 LG
              1981 LH
