Gents,
I had to remove my centerstand on my 1979 standard. The hardware had been replaced in the past (probably after the original owner crashed and repaired it) (it is 3/8" grade 5 hardware...) and it is definitely not stock.
As it came off, the left mount had a spacer in the centerstand that went over the bolt. The outside hole is much smaller than the inside hole, so the spacer would hit against the outside of the bracket but would "poke through" the inside of the bracket. When the nut was tightened down, this would "crush" the spacer against the outside of the mount and cause the centerstand to pivot on the spacer instead of the bolt. The left side also had this funny bracket around the outside of the frame bracket as well:
You can also see the bolt that was in there and the spacer. The right side was setup the same except it was missing the spacer and it did NOT have the bracket around the frame mount.
From looking at the (crappy) parts diagram I could find, it appears the stock center stand bolts were large diameter that provided the pivot surface directly with a smaller diameter threaded stud that was installed from the inside and then had the small nut installed on the outside to secure the stand and provide the pivot points. The only reason I can think that my bike would be different is that it does have a Kirker 4-1 exhaust on it (again, OE installed. Probably after his crash!). But for the life of me, I can't figure out what that little bracket would do.
Does anyone know what that bracket is for? Also, does anyone know were I and get the correct bolts and nuts for the centerstand? I was planning on making up a new spacer and getting 10mm bolts to refasten the stand, but if the factory had better hardware with the "spacer" already on the bolt, that would be a better solution in my opinion. Anyone have any of these things I could have/buy?
Thanks for the help!
