rear brake switch removal dumb question...
  • le_bucheron
    • Sep 2012
    • 45
    • Montreal, Quebec, Canada
    Ive tried to remove my rear brake switch but I think the lower plastic nut is stuck... I don't want to break something so do you have any tips? How you remove this nut?
    83 XJ1100
    06 FZ1 naked abarth
    It should just un thread off of there.
    • dpotter58
      • Aug 2004
      • 1866
      • Southern Maryland
      Are you pulling it because it's not working? Buy a new one on ebay for $10 and it comes with a metal nut
      1980 LG
      1981 LH
      • Gallaecus
        • May 2011
        • 254
        • East Haven Connecticut
        you could try unbolting the rear master cylinder and letting it hang so you can get better access to the switch ???
        Steven
        1981 XS 1100 LH
        1979 XS 1100 SF
          First, reach in with some bent-tip needle nose pliers and disconnect the lower end of the spring from the brake lever. After that, the switch assembly should just lift straight up from its mount, and the plastic nut will spin freely.
            Welcome back Ken!
