Out'a sight and blemish free!
Do you have a small handheld scale you can use to measure the advance spring tension when you get the parts and before you put them on the engine? Crazy Steve made the Interchange Tech Tip but didn't delve that far into it. I want to at least try to measure the spring tension of the different advance assemblies when they first start to allow advance and when they're 'all in'.
For the rest, the '79 and '80 timing wheels are marked in 5 degree increments. Any of them can work with the 10 degree setting for the '78 ignition but the 'F' mark will be off by 5 degrees so the '78 wheel is much more cooler.
It may or may not be true in the real world but the graphs in the good book of Yamaha show that the '78 and both '79 models use the same vacuum advance pot:
Min. 0 degrees advance @ 1.96 inHg (50 mmHg)
Max. 16 degrees advance @ 5.9 inHg (150 mmHg)
You do not want to know what they did for the '80 and '81 vacuum pots.
