The guy I got my bike from had converted the turn signals to LEDs. He used a ton of connectors and questionable solder joins in the process. The signals would not flash at idle so I decided to remove the leds, connectors, and solder joints in the hopes of resolving the problem. He also added a custom Halogen headlight and speedo that work and look cool so I decided to leave them. I cleaned up the wiring on these as well. I have replaced the LEDs with incandescent bulbs and replaced the Regulator as well. The turn signals will flash at idle sometimes and sometimes not. I am thinking that the Halogen headlight may be loading the system to the point that the voltage at the turn signal flasher unit is above threshold. I dont want to change the headlight because it works well. If someone has any known good voltage readings at the flasher unit I would appreciate the readings. Any suggestions would be greatly appreciated.
