Aftermarket Master Cylinder
  • D0wn5h1ft
    • Aug 2013
    • 515
    • Westerly, RI.
    The master cylinder assembly on my bike is pretty much a lost cause. There's cracks in the reservoir, etc and it most likely needs to be replaced. I was browsing ebay for a replacement but stumbled across several aftermarket "generic" alternatives. This there any reason why replacements such as these wouldn't work?:
    http://www.ebay.com/itm/Yamaha-XJ-Br...1f6891&vxp=mtr
    http://www.mikesxs.net/product/08-0255.html
    http://www.mikesxs.net/product/08-4004.html
    Namely, the first one because it is the most affordable. I assume all I would have to do is take off the old master cylinder and plug the old brake line into the new MC.
    78 E - 2to1 exhaust, dynatek coils, special headlight [SOLD!]
    79 F - gas tank refurb, headgasket change, straight pipes, late model carbs, virago lowering shocks, special headlight and gauges, TC fuse block, GSXR-1100 carbs (WIP)
    "May my tires not fail me, nor my engine grow cold"
    • 8962
    Just be careful of the piston size, larger bore is for dual front brake rotors, smaller for single. Then there is the mirror mount to consider. Left or right handed threads.
      If you want to be sure you get exactly what you need, contact Michael Morse at 650 Central.
        There is a compatibility listing for the eBay master cylinder. If you run it for XS1100 it says it's OK. If you run it for XJ650 Maxim it says OK.
        This can not be, as the XS1100 is dual caliper and the XJ650 is single caliper. I would leave that one alone!
        • rdmcguy
          • Jul 2013
          • 515
          • Denver, Colo.
          master cylinder
          I don't know about he aftermarket ones,
          But had a leaky warped stock one, couldn't correct it, so bought a brand new one for an fj 1200 smaller mirror mount and no front brake light sensor
          (think I saw aftermarket ones on forum?)
          Was designed for dual discs, easy mounting great feel,$120.00 new
          at local dealer, Does not come with lever.
          • MPittma100
            • Aug 2011
            • 2359
            Ebay
            Here is one on-line. May need a kit, but looks usable.
            http://www.ebay.com/itm/Yamaha-XS110...4cf21f&vxp=mtr
            MP
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • Rasputin
              • 3193
              • Lacombe, Alberta, Canada
              MP
              Man that thing is about 100 bucks over priced.
              2-79 XS1100 SF
              2-78 XS1100 E Best bike Ever
                • 4015
                Being the generous guy that I am, and coming from an ARMY family, I happen to have an extra master cylinder with brake lever and switch. I dunno if it's good or not, but that's for you to decide. Send me the price of shipping, and she's your's.
                • jwhughes3
                  • 2798
                  • Home of the Alamo
                  MikesXS.net
                  Here is what I have used on my 80SG along with SS lines it works great.
                  http://www.mikesxs.net/product/08-0265.html
                  $87
                  John
                  '81 XS1100H - "Enterprise"
