xs11 Performance mods
  • joep7
    • Jun 2013
    • 98
    • Grand Rapids, Mich.
    One issue with a chain conversion is there isn't enough room to run a decent-sized front sprocket without extensive mods to the engine cases. I believe a 14 tooth is about it, and chain life will suffer.
    Hmm alright. I'll look into what the guy I am copying did. Also reading the other posts on here by xschop.
    72 Cb900 C
    72 Cb350 Track Bike
    86 Rebel 450
    79 XS11 Standard
    • joep7
      • Jun 2013
      • 98
      Doing some pricing and research regarding the chain swap and other bits. Would the swinger and front end from an fj1100 or 1200 work on an xs11. Would it be much of an upgrade front end wise?
      72 Cb900 C
      72 Cb350 Track Bike
      86 Rebel 450
      79 XS11 Standard
        I doubt the swingarm would be anywhere even close to being able to work. The FJ11 front end will fit with some modification, the forks are beefier and set further apart than the XS, but they are still damper rod forks.
        • James England
          • 3039
          • North of England
          #34
          Originally posted by joep7
          I think I'll avoid the nos
          Why? Forget chain drives and big bores. You'll get negligible performance increase and it will cost a fortune.
          I had 175bhp on my XS thanks to http://www.noswizard.com/
          • joep7
            • Jun 2013
            • 98
            #35
            Im not doing the big bore. The chain drive will not cost me much to make. We have a FARO arm at the shop and CNCs to do the mill work. Im more doing it to learn a lot more about Solidworks and running a CNC.
            72 Cb900 C
            72 Cb350 Track Bike
            86 Rebel 450
            79 XS11 Standard
            • joep7
              • Jun 2013
              • 98
              #36
              What about the fzr front end?
              72 Cb900 C
              72 Cb350 Track Bike
              86 Rebel 450
              79 XS11 Standard
              • James England
                • 3039
                • North of England
                #37
                Was wondering if anyone knows of any good bore upgrades. Id like to keep the sleeves in it and just go up a few mm with oversized rings. But I wondered if maybe a 650/750 twin or some of the bigger triples had pistons that would swap with a bigger bore????
                You not doing this aspect of things now?
                • joep7
                  • Jun 2013
                  • 98
                  #38
                  I decided against e big bore. Just got it honed and I am replacing rings for now. Sounded like from you and others that the bore would not increase hp much.
                  72 Cb900 C
                  72 Cb350 Track Bike
                  86 Rebel 450
                  79 XS11 Standard
                  • WMarshy
                    • Apr 2009
                    • 2402
                    • Mexico NY
                    #39
                    Anything is possible, your only limitation is your skills and resource$. Not many people have gone to moderen inverted forks. The most popular upgrade for the front end is FJ forks. Do a search and you will find the details for the swap.
                    '79 XS11 F
                    Stock except K&N
                    '79 XS11 SF
                    Stock, no title.
                    '84 Chevy K-10 "Big Blue"
                      #40
                      Here's the FJ fork conversion...
                      • joep7
                        • Jun 2013
                        • 98
                        #41
                        http://www.xs11.com/forum/showthread.php?t=25786
                        Thanks Steve
                        72 Cb900 C
                        72 Cb350 Track Bike
                        86 Rebel 450
                        79 XS11 Standard
