A Hypothetical . . .
    • 4015
    What would happen if one petcock stopped working and only two of the cylinders ran? What would happen to the other two cylinders? too hot and burn.a hole in the piston?
    Don't know and since I connected all 4 it will never be an issue for me!
      • 4015
      I've been thinking about doing exactly that to prevent that from happening.
        The cylinders that are getting fuel would be the ones that could be damaged. But you'd notice the power loss before anything happened....
          I mounted a pipe on the bottom of the bowls with 2 T's to connect them to the carbs and on each end there is an elbow to connect to the petcocks.
          Most of the time I only turn one petcock on. It is only if I hit reserve when I turn the other on.
          • GLoweVA
            • Jun 2011
            • 1957
            • Virginia Beach, VA.
            Agreed that you would notice the power loss, but what if you HAD to limp it home on 2 cylinders?
            You'd melt some holes in the 2 pistons that stayed running. Don't ask me how I know.
            My failure wasn't a petcock, but the head gasket, thus 2 of my cylinders lost.
            I had about 15 miles to get home and the fastest I got was about 35mph.
            Oh, thinking back, 4years ago, when the pickup coil wire went bad on my G and I limped it home, that's when I burnt my first hole in one of those.
            Next time, I call the wife and have her bring the truck.
            80G (Green paint(PO idea))
            The Green Monster
            Got him in '04.
            bald tire & borrowing parts
            Scarlet
            Got her in '11
            Ready for the twisties!
            81H (previously CPMaynard's)
            Hugo
            Cold weather ride
            • CRXSi90
              • Jun 2004
              • 400
              • Madison, Wisconsin
              How did the 4-6-8 v8 engines work then?
              '81 XS11H Venturer - holed up in storage while life happened since 07/08/04
              '81 Kawasaki KE175 enduro - 63 mph of smokey fun, now with collector plates!
              • CRXSi90
                • Jun 2004
                • 400
                Oh, and Greg/BA80 claims to have done exactly this in the LOST rally thread. Apparently it worked for 5 miles for him...
                https://www.xs11.com/forum/showpost....3&postcount=79
                • GLoweVA
                  • Jun 2011
                  • 1957
                  I suppose as long as you didn't push the engine too hard then the remaining cylinders (be it 2 or 4) could provide enough power to keep the engine speed up without over doing it on the ones that were firing.
                  Then again on the fuel injected computer controlled engines, the o2sensors and such should keep the fuel mix not too lean and therfore not to hot.
                  The Green Monster
                  Got him in '04.
                  Scarlet
                  Got her in '11
                  Hugo
                  Cold weather ride
                  • sparkfly88
                    • Mar 2013
                    • 585
                    • CedarKey FL
                    On the way back from Ohio...
                    In North Carolina, as we were getting fuel, the vac line for my rightside petcock popped off.
                    I got on the highway and it lost ALL power, it sounded very airy, like an aircompressor, not an engine at all...I thought something blew up...lol.
                    I gimped to the next exit at like 30mph with it throttled up.
                    Shut the engine off, found the vac line, coughed and belched then fired right up!
                    79F
                    "Excelsior"
                    Honda gl1100 handlebar
                    Vetter IV fairing with speaker system
                    OE headers,Jardine slipons
                    Hid headlight 6000k
                    Stock jets
                    Shinko 712 F & R
                    Oe hardbags and luggage rack
                    TC fuse block
                    K&n filter with oe airbox
                    Raptor 660 Acct
                      • 3193
                      I pretty much agree with Steve on this one. The two that have no fuel will not produce any unwarranted heat due to not firing. The oil and all that will stay in play so no big deal.
                      I think (and may be wrong) that the two cylinders still running the bike will require extra fuel to try to maintain life. That alone will cool the engine a bit as well as enrichen the two working cylinders.
                      You would absolutely know there was a power loss at any speed and then figure it out pretty quickly after that. Your ride will be ruined until the fuel is corrected.
                      • CRXSi90
                        • Jun 2004
                        • 400
                        So just to hypothetically push this a little further.........
                        I believe GLoweVA's actual experience, but I follow the hypothetical explanations. Was the piston holing possibly due to the jetting? I'm thinking something along the lines of that the jetting was too lean for high load situations. The jetting was okay for intermittent bursts, and the heat developed could dissipate into the piston fast enough. Typically you can only stay on the throttle so long before you find a corner and have to slow down! If there were a sustained high load situation (pulling trailer in 100mph headwind), then the same holed piston problem might have occurred on all 4!
                        I'm just asking with curiosity and interest and trying to learn; no bad intentions here.
                        • GLoweVA
                          • Jun 2011
                          • 1957
                          In my case I rode the bike home and trying to accellerate on 2 vice 4 is hard to do.
                          Just getting off the line at a stop light was hard. I pushed the bike hard on those 2 running cylinders and they got too hot. I was at times WOT just to maintain speed at 40 mph so I wouldn't get run over by the cars.
                          Stock jetting, so they shouldn't have been too lean in the first place, just pushing them that hard and that long did them in.
                          I also agree that the theory should work too and maybe in a different set of circumstances mine might not have done that. In my case it was 2 and 4 that went bad.
                          If it were a fuel flow issue (like wht this thread started out as) then it would be a 1&2 or 3&4 pair and maybe that would change how the engine developes power.
                          The Green Monster
                          Got him in '04.
                          Scarlet
                          Got her in '11
                          Hugo
                          Cold weather ride
                          • MPittma100
                            • Aug 2011
                            • 2359
                            Hole in Piston
                            I am having trouble figuring out how the two cylinders that burned the pistons overheated enough to do that?
                            MP
                            1981 XS1100H Venturer
                            K&N Air Filter
                            ACCT
                            Custom Paint by Deitz
                            Geezer Rectifier/Regulator
                            Stebel Nautilus Horn
                            EBC Front Rotors
                            Limie Accent Moves On In 2015
                            Mike
                              I too am puzzled how the two getting fuel will get damaged. To some degree these engines are almost four independent engines. I get there is a lot of work to be done. But unless your going WOT on those two AND getting the high revs, not sure I see it.
