I'm going to rehab a set of BS34 carbs for my XJ11. I want to compare the stage 1 Dynajet kit with stock carbs. I have stage 1 in the XJ right now and also have the YICS eliminator in the passageway. Last year I bought a spare set of XJ11 carbs and want to put new jets in all around, new slide needles, replace the float valves, throttle shaft seals as well as give it a through cleaning in carb dip & with compressed air.
Normally I wouldn't want to replace the jets but after I re-did my Maxim-X carbs 3 times only to have #4 be extremely over-carboned, I gave up. A friend replaced the pilot jets with new and a known good emulsion tube was put in #4 and that was the fix; Went from a max of 33 MPG to a max of 49 MPG. I couldn't see anything wrong with them with magnifying glasses...
So to do these right, I'd like to make sure all the moving pieces/jets are replaced with new.
I'm wondering if the jets & needles from Dennis Kirk would work well https://www.denniskirk.com/rd-bs30-9...uestid=3909840 or should I get Mikuni jets? Also wonder if these throttle shaft seals are right for the XJ11 http://www.mikesxs.net/product/48-5021.html And is there a good source for new main nozzles/emulsion tubes & slide needles to fit each other?
Lastly, with the YICS eliminator in, should I use the jets for carbs on a later model XS that uses this same carb? Or, should I use the jets for the stock XJ?
Stock XJ11 jets are:
Main Air - 170
Pilot - 47.5
Main - 112.5
Idears?
So to do these right, I'd like to make sure all the moving pieces/jets are replaced with new.I'm wondering if the jets & needles from Dennis Kirk would work well https://www.denniskirk.com/rd-bs30-9...uestid=3909840 or should I get Mikuni jets? Also wonder if these throttle shaft seals are right for the XJ11 http://www.mikesxs.net/product/48-5021.html And is there a good source for new main nozzles/emulsion tubes & slide needles to fit each other?
Main Air - 170
Pilot - 47.5
Main - 112.5
Idears?
