Clutch does not engage
  • TONIO
    • 60
    • HOUSTON TEXAS
    I have an 81 special I just started having issues with the clutch. Once I start the bike when I try to engage the clutch and go into
    First gear tHe bike stalls . Seems that clutch is not doing what it's suppose to?
    I tried tightened at the clutch lever. Any ideas guys?
    Thanks in advance for the help.
    Tonio
    tonio
    81 xs eleven special
    Adjustment is down at the engine...
    • TONIO
      • 60
      • HOUSTON TEXAS
      Thanks Phil I will try tis.
      tonio
      • rpgoerlich
        • Dec 2007
        • 643
        • Katy, Tx
        Had the same problem after I pressure washed mine a few years ago.
        Nuetral safety circuit was shorted. It dried out and no problems since.
        Richard
          +1 Richard. That's what I was thinking. Pick up coil wires shorted to the neutral switch wire. Classic symptom.
            If the bike has been sitting for a long time, the oil film between clutch plates are likely sticky. There are some threads in the forum on how to deal with that.
