When to re-build Master Cylinders?
    • 4015
    So, I have some master cylinder rebuild kits, and the brakes seem to work okay. Not sure of the condition of the pistons, but I have a sqeak every now and then. I see James's post about wheel bearings, etc., and I kind of curious to know when it's time to start replacing/rebuilding stuff. When do I know to re-build my master.cylinders?
    Have you disassembled and cleaned the brake system since you got the bike?
      The short answer to when to rebuild the Master Cylinders is when they stop working. Now, I am not saying it would be ill-advised or wrong to do so now. If your bikes MC has never seen the light of day since it was made to the best of your knowledge, I would give some serious consideration to it. But there is no time limit or miles limit to when that should be done.
        • 4015
        No, Scott maintained the bike very well, so there are many things I have never touched with the exception to the brake pads, and carbs, ACCT, etc.
