Pulsing front brakes on Special?
  • GLoweVA
    • Jun 2011
    • 1957
    • Virginia Beach, VA.
    I keep reading about the front brakes 'pulsing' on the specials if the caliper mounting bolt is slightly bent.
    Any more info on this?
    I'm not sure if my bolt(s) are bent, (I don't remember anything out off the ordinary when I reassemble them last year) but when at a near stop (<10mph) my front brakes grab intermitently (ie pulse) and of course the bike tries to dive a little as the pads grab more then as the pads release, the bike comes back up.
    It's a little annoying, but the brakes DO grab well at speed and I don't feel any pulsing while zipping along. (example, on the interstate when traffic is suddenly stopped in front of me and I lay into the brakes and she slows down just fine, then when I get to about 5mph or so, it starts pulsing and doing the nose bob up/down. I just ease up on the front and finish slowing down with the rear.
    Any ideas of similar symtoms with anybody else?
    80G (Green paint(PO idea))
    The Green Monster
    Got him in '04.
    bald tire & borrowing parts
    Scarlet
    Got her in '11
    Ready for the twisties!
    81H (previously CPMaynard's)
    Hugo
    Cold weather ride
    George,
    The first thing to try is cleaning the rotors. Get some 100 grit garnet paper and go after them. Sand them as well as you can followed by some brake cleaner. This might fix it.
    I recently went after a junkyard rotor with a paint stripping wheel. It cleaned it off real well. As it turns out, the rotor is warped. I can see it, as the caliper on my XS650 is moving in and out. I can not feel this when I apply the brake at any speed. Try the garnet paper.
    • GLoweVA
      • Jun 2011
      • 1957
      Thanks Marty, it may just be something as simple as that. I 'sticky' spot on the rotor.
      Once I figure it out I'll post back up for the info for all.
      The Green Monster
      Got him in '04.
      Scarlet
      Got her in '11
      Hugo
      Cold weather ride
        Check those bolts while you're at it. If they're bent, I suppose that could be the problem. Still, it won't hurt to get after the rotors with the paper as well.
          The bent bolt thing makes no sense at all, the bolt is stationary and can't affect the moving parts at all. I have a warped/bent rotor on the spare front for the SG.
          You just need to figure out which one it is, I clamped the line one at a time on mine to do that. It's the right rotor that needs replacing. Sometimes you can just take it off and clean the mounting surfaces and cure it but that didn't work on this one. I can see the warpage in the contact marks.
          It's irritating but isn't really an issue unless you hit the front brakes at over 80 then the bars vibrate pretty bad.
          • 650mark
            • Jul 2012
            • 307
            • Mesa, Az.
            I just went through this issue about a month ago with my '80 special. front brakes pulsed when applied at just about any speed, more noticeable when coming to a complete stop. after having both rotors turned/trued and installing new pads still did it. replaced both caliper bolts and problem gone.
            I agree, doesn't really make sense but the new bolts cured the problem. for sure try that first, for about $2.00, before you start spending money on machine work and other new parts.
              If a bolt can make that light spot on the inside of the contact area on the front of this rotor I need someone to show me.
                Greg,
                Try deglazing that rotor with sandpaper or a paint stripping wheel. I have a warped rotor on my XS650 and it does not pulse.
                  Marty, thanks bro but deglazing won't take the obvious warp out. A glaze won't make it skip contact half the distance around.
                    No Greg, you're right. It will never take the warp out. I have fixed the pulsing sensation in both the bike and the car with garnet paper. I just thought I'd put that out there.
                      The one thing I'd be concerned about with a warped rotor is excessive wear on the pad retainers (the stainless steel wear clips) and the caliper mount on the standards. The clips in particular are becoming unobtainium, and as-designed, any caliper movement is supposed to be minimal and gradual to account for pad wear.
                        I'm not OK with the warped rotor. I'm going to replace it soon. I wanted to point out that a pulsing in the brake is more likely a glazed rotor than a warped one. Of coarse, when it's warped as bad as Greg's, all bets are off.
                        • ViperRon
                          • Feb 2011
                          • 1062
                          • Woodstock, VA
                          Steve when you talk about the clips for the Standards being unobtanium they are $5.00 as a kit on Mikes XS. You get the spring clips and screw in one kit. Part #29-3200 At least I think that is what you were talking about.
                          http://www.mikesxs.net/products-101.html#products
                          Rodan
                          1980 G Silverbird
                          1198 Overbore kit
                          Grizzly 660 ACCT
                          Barnett Clutch Springs
                          R1 Clutch Fiber Plates
                          122.5 Main Jets
                          ACCT Mod
                          Mac 4-2 Flare Tips
                          Antivibe Bar ends
                          Rear trunk add-on
                            Nice to know that these are now being reproduced.....
                              The ones for the Special are the hard to find ones.
