I have brought this up in the past some but I want to go a little deeper and actually get this done finally.
I already have replaced the side marker lights on my Pacifico fairing with LEDs and found that Blazer product C555A is a perfect replacement for the whole light fixture. It is the exact size and style as the original light.I had talked before about making the side marker light flash with the turn signals and now is that time.
So when I am going to do this I need to also make the forward facing clearance/turn lights LED as well. For the life of me I cannot find a light that is the same size as that stupid light. It is 3 15/16" X 2 15/16" call it 3x4 or whatever but I cannot find an amber colored clearance/turn light anywhere! So if any of you know of one LET ME KNOW!
Anyways, since I can't find a light to replace that forward facing one with and those spendy little 1157 LED bulbs suck (not bright at all) I figure I will have to make something. So what I was thinking was I could take 2 separate LED panels and wire one to the clearance light circuit and another to the turn signal circuit and then mount the panels inside the light housing right up by the reflector. Then add in a solid state NC relay to the ground wire on the side marker light that is triggered by the turn signal circuit to make it flash.
Problem is if it doesn't work I might not be able to go back to the original way, and if this still is not bright I might be screwed so I am using you all to bounce ideas off of.
He bought a pair for his Datsun Roadster, and you could NOT see them unless you were in line with the bulbs. As the lights on the car are about 16" above the ground, they didn't work. He then spent more money, and bought the bulbs that have the LED's in a globe pattern. The lights work well, and do NOT take as much juice as the stock.
