I heard a rattle/buzz from my No. 1 header pipe, so grabbed it after it cooled down, and have found the outer pipe is seperated from the inner pipe. Youcan literally wiggle the outside pipe around inside the edges of the header clamp. Haven't taken it off yet, but am wondering what I'm up against? Can these inner and outer pipes be rewelded together somehow?
Double wall header pipe seperated??
Not a common problem, but not unknown either.... The XJ I'm rebuilding did this, and the entire pipe fell off on the freeway.
You need to get that fixed before the inner pipe breaks too. Clean the joint as best you can and MIG or TIG weld it back up. Make sure the drain/vent at the other end of the pipe is clear before welding.Fast, Cheap, Reliable... Pick any two
Originally posted by crazy steve View PostNot a common problem, but not unknown either.... The XJ I'm rebuilding did this, and the entire pipe fell off on the freeway.
You need to get that fixed before the inner pipe breaks too. Clean the joint as best you can and MIG or TIG weld it back up. Make sure the drain/vent at the other end of the pipe is clear before welding.81H Venturer1100 "The Bentley" (on steroids) 97 Yamaha YZ250(age reducer) 92 Honda ST1100 "Twisty"(touring rocket) Age is relative to the number of seconds counted 'airing' out an 85ft. table-top.
