Anyone ever have this happen?
I had the motor out of the frame and the head and jugs off back in 2009. I assembled everything back and torqued the head bolts in stages to the specification and after riding a few hundred miles re-torqued them again to specification (they had not changed). I check this every spring during my yearly major tune-up and they have always been on specification however I never did the tune up this year (I know, shame on me).
Recently I noticed a bit of oil between the cooling fins where the head meets the top of the cylinders on both sides. Also there was a small trail that ran through the head and down into the valley where the #3 plug is. I figured the cam chain tensioner but it is sealed up and dry. After looking all over with a flashlight I noticed a wet area at the base of the cylinders at the front of the motor and oil trails leading up the motor caused by wind.
I know I had sealed this area well when I had the motor apart as it has never leaked until now. I figured I could pull the head and lift the cylinders a bit to get something in there to seal off again so I started to loosen the acorn head nuts. They were all at only 5 Lb/Ft consistently. When I discovered this I re-torqued them to specification, cleaned the motor off and the oil leak has stopped.
I am stumped as the head bolts have remained tight for several years and now they all loosen to 5 Lb/Ft consistently? Has anyone else had such a thing happen? Does anyone else care to venture a guess at a cause?
Thanks cause I am stumped on this one.
