Exhaust studs
    The stuff for rust, etc. is a 70% acetone 30% auto-trans oil mix. It will work BETTER than ANY store bought item. That with heat/cool for the head/studs SHOULD help get them out.
    And Yeah, I try NOT to volunteer anymore.
    • Tat2demon
      • Jun 2012
      • 718
      • Sioux Falls, South Dakota
      Its funny you mentioned that. Its the second time Ive heard it today. Ive never heard of it before. How is it for penetrating?
      Nate
      78 XS11 "Matilda" 2H7 000364
      K+N Air Filter
      88 Voyager XII
      81 XJ650 Maxim
      • Tat2demon
        • Jun 2012
        • 718
        Success! 2:30 am but I got that bastard out. Thanks for the advice and support guys!
        Nate
        K+N Air Filter
        88 Voyager XII
        81 XJ650 Maxim
        • Prothec
          • Jul 2007
          • 587
          • Fort Myers, FL
          Originally posted by tarzan
          You dont need a diamond cutter. You do need a carbide cutter though. . . . Also, that ez-out is hard.You may be able to strike it with a punch with a hammer and shatter it.
          I was able to break up a broken extractor in a broken exhaust stud on a 97 Honda Accord. Apparently extractors don't do anything but break unless you remedy the reason the bolt broke in the first place...
          Website/Blog
          • Diskman01
            • Mar 2011
            • 263
            • Sioux Falls, SD
            Hey. Go out and pick up a set of "reverse drill bits". 60% of the time they work every time for broken bolts.
            Or I can drop mine off for ya if you still need to drill out studs.
            1) Fire up Internet Explorer
            2) http://www.yahoo.com
            3) type "www.mapquest.com" into the Yahoo search page.
            4) go about day as VP managing multi-million dollar financial contracts.
            • Prothec
              • Jul 2007
              • 587
              • Fort Myers, FL
              +1 on that. Harbor Freight has a cheap set in a metal case. When I bought mine, that's the only place I found them.
              Website/Blog
              • Tat2demon
                • Jun 2012
                • 718
                So the drilling/tapping didnt go trouble free. While tapping one of them stripped out. Looks like its time for a helicoil. Can anyone tell me how they are measured? Are the 8m sets 8m outside inserts or are they for 8m original bolts?
                Nate
                K+N Air Filter
                88 Voyager XII
                81 XJ650 Maxim
                  • 4015
                  They are measured based off the thread and pitch of the bolt. If you're using metric, you find a insert for the stud you want to thread into the insert. You basically epoxy the helicoil in, and it's good to go.
                  • Tat2demon
                    • Jun 2012
                    • 718
                    Great thanks.
                    Nate
                    K+N Air Filter
                    88 Voyager XII
                    81 XJ650 Maxim
                    • dondons1984
                      • Jun 2013
                      • 153
                      • Walla Walla, Wash.
                      had this same thing happen to me with my goldwing. I ended up going out and buying a extractor set and the whole shabang. wasnt a waste of money cause I have now used it 4 times and it saves my ass every time. Takes awhile but when you get it out you are happy.
                      79 SF
                      Wow, did I just give advice? should I be doing that?
                      1983 GL1100 bored to a 1300 sold
                      1976cb750 project gifted to brother
                      1979 xs1100s currently working on
                      Wanting to have that head turner that makes people shut up!
                      • tarzan
                        • 1700
                        • Chandler,Az.
                        Heli-coils are not normally epoxied in.You tap the hole with an STI tap(heli-coil tap), then install the heli-coil and remove the little tang from the bottom coil. It won't come out easy after that.
                        80 SG XS1100
                        14 Victory Cross Country
                        • WMarshy
                          • Apr 2009
                          • 2402
                          • Mexico NY
                          Check this out...
                          Time Sert thread repaid...
                          '79 XS11 F
                          Stock except K&N
                          '79 XS11 SF
                          Stock, no title.
                          '84 Chevy K-10 "Big Blue"
                          • Tat2demon
                            • Jun 2012
                            • 718
                            This project got bad tonight. Realized one of the broken studs is right behind the frame so the only option now is to pull the motor/head and Im just going to take it to a shop.
                            Nate
                            K+N Air Filter
                            88 Voyager XII
                            81 XJ650 Maxim
                              • 3193
                              Unless you have one of those dremel attachments that Flexes (a tube with a drive in it similar to our speedo's) I think you are done. Sorry.
                              • Tat2demon
                                • Jun 2012
                                • 718
                                Ooo I do have one of those! Bought it and its been sitting on a shelf for about a year.
                                Nate
                                K+N Air Filter
                                88 Voyager XII
                                81 XJ650 Maxim
