Exhaust bolts
  • tarzan
    • 1700
    • Chandler,Az.
    Exhaust bolts
    Can someone post a pic of the OEM exhaust bolts and washers that fasten the rear of the exhaust on a 80-81 Special. I seem to be missing something on mine. There is that big hole in the mount that looks like it accommodates some kind of grommet.This bike I'm working on did not have that.And I have never really paid much attention to the actual hardware.
    80 SG XS1100
    14 Victory Cross Country
    Yep, there sure is. HERE is the part.
    You have to look at the Stand - Footrest detail in the parts fiche.
    • tarzan
      • 1700
      • Chandler,Az.
      That's a bummer. Discontinued
      80 SG XS1100
        Hi tarzan,
        you should be able to kludge up something to do the job.
        A piece cut off a kickstart rubber with a bolt through it and two fender washers would be my first thought.
          Kinda of like highway robbery, but....CLICKETY
          And..A little more affordable....CLICKETY
          • MPittma100
            • Aug 2011
            • 2359
            Make Offer
            Make an offer on the first "CLICKETY". See what happens.
            MP
            1981 XS1100H Venturer
            K&N Air Filter
            ACCT
            Custom Paint by Deitz
            Geezer Rectifier/Regulator
            Stebel Nautilus Horn
            EBC Front Rotors
            Limie Accent Moves On In 2015
            Mike
            • tarzan
              • 1700
              • Chandler,Az.
              Thanks guys
              I went ahead and put an offer on two of those from the first link. About half what hes asking. Andreas sent me a pm. Maybe he will have the whole brackets.
              80 SG XS1100
              • tarzan
                • 1700
                • Chandler,Az.
                I was just thinking, maybe I could use a couple of those bushings from a stabilizer bar from a car?
                80 SG XS1100
                  IIRC, the rubber bushing is an hour glass shape so once pressed in, it can not fall out. If you look at the bracket, it should have a smaller diameter in the center of the bushing hole.
                    The purpose is to isolate exhaust vibration from the footrest bracket. You should be able to use any type of rubber sleeve, and rubber pads where the metal washers meet the bracket.
                    • tarzan
                      • 1700
                      • Chandler,Az.
                      I need the bracket too. I'll come up with something.
                      80 SG XS1100
                        Ohhhh, that's a horse of a different color. Which side or both?
                        • tarzan
                          • 1700
                          • Chandler,Az.
                          Both.The midnight was in pieces and missing a lot of parts.The SG I am using as donor had some goofy strap steel barely holding the Mac pipes up.
                          I would like to hit the wrecking yard this week, but it's 110 degrees this week.
                          80 SG XS1100
