The engine has been getting hard to start in the morning after a riding it the day before and a heat-soak/cool-down overnight.
It also seems to be losing fuel from the fuel line and float bowls of the #3 and #4 carburetors. The bike is level and parked in the garage on the center stand. There is no fuel in the airbox or in oil, it's clean.
It's slowly been getting worse and worse over the last few months. Yesterday, it the engine just cranked and cranked and wouldn't start.![Mad](https://xs11.club/core/images/smilies/mad.png)
The Basic Checks:
Standing battery -- AGM battery, ~13V
TCI voltage with the ignition on, engine not running -- 12.7V
TCI voltage during cranking -- ~11.5V
The TCI is good. I swapped in a spare known-good TCI and it works fine too, once the engine has been started in the morning, so it's not likely to be a TCI problem.
The static and dynamic ignition timing are good.
The vacuum advance works smoothly as does the mechanical advance.
The spark plugs are Iridium plugs gapped to 0.032". They're clean and have less than 2K miles on them.
The ignition coils are the 3 Ohm Accel coils that do not require the ballast resistor so it's been bypassed. The coils throw a nice, hot blue spark that can be seen in full daylight at all four plugs.
The cold cylinder compression numbers #1 to #4: 147/149/150/149 with the throttle wide open.
All of the above seems to point to the carburetors as the most likely suspects so I pulled off the '80G carburetors and put on a spare set of stock XJ1100 carbs.
The 'new' XJ carbs worked fine and the engine fired right up. They still need to be synchronized but they're pretty darn close the way they are now so I went for a ride last night, then put the bike in the garage for the night.
When I tried to start the engine this morning it had the same problem. Before I started the engine I looked at the clear fuel filters and the left-hand filter looked empty.
I started to think about that and after the burning smell finally went away and the dog quit howling I remembered that the fuel lines are overlength and crossed so I can use the fuel tank to synch the carbs. When the left-hand filter is empty it's not #1/#2 carb, it's #3/#4 and vice versa.
Apparently the #3/#4 carbs lose about one fuel line and a small filter of fuel overnight.
Tomorrow morning I'll try putting the fuel taps on Prime for a few minutes and tap on the float bowls to see if the filter fills back up before starting the engine and see if that works or if it's going to fight me the whole way.
It is highly unlikely but not impossible for two different sets of carburetors to lose fuel from the same pair of float bowls so I'm more than a little curious about what's really going on and even if putting the fuel taps on Prime fixes the hard starting problem I still have to figure out where the fuel is going.
It didn't used to do this.
The Basic Checks:
![Frown](https://xs11.club/core/images/smilies/frown.png)
