I recently rebuilt the carbs with K&L jets from Georgefix using the stock settings of 137.5 mains and 42.5 pilots. I could not get it to idle for the life of me and trying to sync the carbs and get the highest vacuum resulted in no change when screwing or unscrewing the idle mixture screws. Pulled the plugs and 2&3 were darker than 1&4 which were light tan/white. #3 was almost black and there was black residue in the carb throat and throttle plate. Turns out the floats were set low as I had to reset them all.
So after reading the jetting recommendations I did the El Cheapo Filter Mod and rejetted with 145 mains and 45 pilots. I reset the floats to exactly 25.7 mm on both sides of the floats and the needles are set to the middle position. The bike idles wonderfully at 1100 and runs pretty well under less than 1/2 throttle up to about 7000 rpm (guess since no tach when riding) and then it will start popping and will not go any further. Also in any gear at any RPM when I roll on the throttle more than half way it will bog down and barely accelerate at all.
Reading here: http://www.factorypro.com/tech/carbt...m_engines.html
It sounds like the jet may be too big, but since it doesn't really pull at all, I am hesitant to buy new jets if that is not the real issue.
Any help?
Any help?
