Changing fork seals without fork removal from bike??
"Excelsior"
Honda gl1100 handlebar
Vetter IV fairing with speaker system
OE headers,Jardine slipons
Hid headlight 6000k
Stock jets
Shinko 712 F & R
Oe hardbags and luggage rack
TC fuse block
K&n filter with oe airbox
Raptor 660 Acct -
2-79 XS1100 SF
2-78 XS1100 E Best bike Ever
Couple of more parts bikes of which 2 more will live!Comment
That just LOOKS nasty! I can only imagine what it smelled like!
Makes me wonder what I'm gonna find when I take my G's forks apart.Hi, my name is George & I'm a twisty addict!
80G (Green paint(PO idea))
The Green Monster
Got him in '04.
bald tire & borrowing parts
Scarlet
Got her in '11
Ready for the twisties!
81H (previously CPMaynard's)
Hugo
Cold weather rideComment
I told you it smelled bad! When I did the model H forks, I didn-t have them pressurized yet it still squirted me in the face when I unscrewed the drain screw.Skids (Sid Hansen)
Following this to the letter:
Originally Posted by crazy steve
There really isn't any 'fork alignment' to lose; particularly if the tops are uneven. Unless you have some bent components and the PO has forced/misaligned bits to compensate for it....
To realign the forks is simple; if you're replacing fork seals, pull both forks off the bike and rebuild them. Reassemble in this order:
1. Loosen the stem bolt on the top tree so it can rotate, and all the pinch bolts.
2. Install the forks in the trees, adjusting 'height' in the trees so the forks are even at the top. How much they are out of the top tree is up to you; I'd make sure the cap clears the tree, you can make minor adjustments in bike height by changing this. Torque the lower tree pinch bolts now. This will 'pull' the forks into alignment in the forks.
3. Lightly snug the stem bolt, then torque the upper tree pinch bolts.
4. Torque the stem bolt.
5. Install the wheel/axle. Torque the axle nut (but not the axle pinch bolt).
6. Check rotor centering in the fork slots. It should be centered on the axle nut side; on the pinch bolt side, push/pull the fork until the rotor is centered, then torque the pinch bolt.
7. Reinstall the brakes, fender, and the fork brace if fitted. That's it!
Doing it like this will allow you to check both forks for matched components, as well as checking your tubes for straightness against each other. This is a good way to 're-set' the forks after a minor mishap too. If you have issues with alignment after doing this, then something is bent. This would also be a good time to look at the stem/neck bearings while you have it apart.
As to the banjo bolt, if it's long enough to safely retain both lines, just drill another hole (90 degrees to existing) where it needs to be.
Results
What am I doing wrong here....
The steering wasnt off before I took it apart ( I think )
79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Raptor 660 AcctComment
Something is bent..... likely the lower tree if the tubes were both straight (you did check them, right?). You have two choices here; get a good triple tree (a set of top/bottom would be best) or try loosening the pinch bolts and 'twisting' it straight by eye. This can be made to work with some experimenting with which pinch bolt to tighten in what order while keeping it 'straight', but isn't the best solution. Any bent components can lead to 'sticky' forks and sometimes weird handling.Fast, Cheap, Reliable... Pick any two
79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Muhahahahah I think this is the problem.
With just the top punch holding the forks, I can hold the tire in my legs and twist my whole front end around!
Now I know what a stem pinch bolt is.79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
The missing top tree stem pinch bolt shouldn't have any affect on aligning the forks/tree; some bikes don't even have this bolt, using the stem bolt to secure the top tree from twisting. It will help retain alignment once you get it right,
No, you have a bent component...
Either a bent tube or a bent lower tree. Try this; remove the stem bolt and loosen the top tree pinch bolts, then pull the top tree off (leave the bottom tree as-is). If after you get it off (and it should pull off without too much effort), if the fork tubes need to be pushed or pulled more than slightly (anything in excess of 1/16") to get the tree to go on, one or both of the tubes are bent or the bottom tree is bent.
If you can twist the forks with just the stem bolt loose, the tube pinch bolts aren't tight enough....
Or the tube holes are misshaped and not clamping properly.... and we're back to a replacement tree.Fast, Cheap, Reliable... Pick any two
I only had the top pinch bolts tight.
Everything else was one turn from tightened.
I'm able to flex the whole front end, which I guess is normal. Lol.
Tomorrow when I'm not getting raped by mosquitos I'll use some patience and really fidget with it.
They were out in clouds tonight, it was awful.79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
Don't forget that the front fender also helps line things up and stiffen the fork flex up too.Hi, my name is George & I'm a twisty addict!
The Green Monster
Got him in '04.
Scarlet
Got her in '11
Hugo
Well I got it all straightened up.
And I forgot to mention, the previous owner did something nice for once, I have progressive springs up front.79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
That is what the 79F comes with stock, progressive wound (type of design) springs, or are you saying you have Progressive brand springs?2H7 (79) owned since '89
☮Comment
Oh. I just see online that they are listed as progressive. So I thought it was an upgrade from the stock springs.
Ahhh marketing.
So, they are stock.
Oh well. So much for me feeling special
79F
"Excelsior"
Hid headlight 6000k
Stock jets
Shinko 712 F & R
TC fuse block
