Changing fork seals without fork removal from bike??
    • 8962
    The Special damping rod is less likely to spin in place and it doesn't have acceptance for the bolt (holding tool) like the Standard does. If need be, a broomstick handle can be used as a tool to keep it from spinning.
    • sparkfly88
      • Mar 2013
      • 585
      • CedarKey FL
      So I checked the preload screws, both were all the way out already ( pretty fascinating how they drop down as you screw them in, one is frozen though. )
      I loosened the top nuts, removed the calipers, and fender, removed the front blinkers looking for the tension bolts, which those ended up being them.
      Then the top.
      Expected em to fall out, of course not!
      Little persuasion from a rubber mallet and some twisting and they came out.
      One, seems like the fluid was changed at some point, the oil conditions and levels were VERY different.
      One had a large quantity of black oil, which I've never smelt before ( gotta be fork fluid ) it took 4 or 5 pumps to empty the oil out.
      the other leaked out some clear fluid ( maybe water ) then two pumps and it was empty, more of a brown fluid than a black like the other one. In the photo its the RIGHT.
      popped the boots off to see the seals.
      And thats where I'm at as of right now!
      79F
      "Excelsior"
      Honda gl1100 handlebar
      Vetter IV fairing with speaker system
      OE headers,Jardine slipons
      Hid headlight 6000k
      Stock jets
      Shinko 712 F & R
      Oe hardbags and luggage rack
      TC fuse block
      K&n filter with oe airbox
      Raptor 660 Acct
        • 8962
        Do one at a time so parts don't get mixed up between the two, or keep the parts separated. Brake cleaner works well to clean the parts off when apart.
        Remember, cleanliness of the internals is very important.
        • sparkfly88
          • Mar 2013
          • 585
          • CedarKey FL
          Well, while I was out getting tools, nature decided to say HEY SCREW YOU!
          All my tools are waterlogged, and the two little screws for the bottom of the shocks are MIA
          79F
          "Excelsior"
          Hid headlight 6000k
          Stock jets
          Shinko 712 F & R
          TC fuse block
          Raptor 660 Acct
          • sparkfly88
            • Mar 2013
            • 585
            • CedarKey FL
            HUZZAH !!!
            I found em!
            79F
            "Excelsior"
            Hid headlight 6000k
            Stock jets
            Shinko 712 F & R
            TC fuse block
            Raptor 660 Acct
            • GLoweVA
              • Jun 2011
              • 1957
              • Virginia Beach, VA.
              Since when doesn't it rain in FLA?!
              You can almost set your clock to the afternoon storms.
              Like the pics, it's always nice to see pic, so others have an idea of what theirs might look like when they take stuff apart.
              80G (Green paint(PO idea))
              The Green Monster
              Got him in '04.
              bald tire & borrowing parts
              Scarlet
              Got her in '11
              Ready for the twisties!
              81H (previously CPMaynard's)
              Hugo
              Cold weather ride
              • sparkfly88
                • Mar 2013
                • 585
                • CedarKey FL
                Thanks! I'll be taking more today when I take Em all apart.
                The one that didn't have much fluid in it is oozing thick funk almost like peanut butter.
                Can't wait to see that gnarly stuff.
                79F
                "Excelsior"
                Hid headlight 6000k
                Stock jets
                Shinko 712 F & R
                TC fuse block
                Raptor 660 Acct
                • sparkfly88
                  • Mar 2013
                  • 585
                  • CedarKey FL
                  Attempt number one is a FAILURE.
                  I read about a way to just use the springs pressure to hold everything in place...So, I balanced on the fork strut like a pogo stick, and gave the 8mm impact a little juice.
                  It broke loose,and then spun around inside the tube, on both.
                  Don't worry, I didnt let the insides spin around to ruin the inside rubber.
                  The moment I felt the inside slip, I let off.
                  I'm sore all over from the awkwardness of balancing on a strut
                  Step two was to take off the top nut, and peer inside to see where this special 19mm double bolt tool goes..
                  I couldnt see anything down there with a flash light that makes any sense to me.
                  79F
                  "Excelsior"
                  Hid headlight 6000k
                  Stock jets
                  Shinko 712 F & R
                  TC fuse block
                  Raptor 660 Acct
                    • 8962
                    Here's the seal puller.... ↓
                    • sparkfly88
                      • Mar 2013
                      • 585
                      • CedarKey FL
                      So the nut tool connects to the part that spins, and you hold the doublenut side or w/e with a socket and extension?
                      idk why I can't wrap my mind around this deal.
                      79F
                      "Excelsior"
                      Hid headlight 6000k
                      Stock jets
                      Shinko 712 F & R
                      TC fuse block
                      Raptor 660 Acct
                        Yes, you will want to remove the spring first, then you put one of the double nut ends down the tube into the damper end, which has a hex head shaped opening in it. Now you use your socket with extensions as needed, to hold the damper from turning as you break the hex screw loose at the bottom of the fork, keep holding the damper rod with this setup till you get the bolt out.
                        The setup Phil showed only has one nut on the end that goes into the damper rod, his must be held by thread lock or some welding tacks. But a double nut on that end will work just as well. His threaded rod is a little shorter than the 18" mentioned, he must have a longer extension.
                        Hope that helps some.
                        • sparkfly88
                          • Mar 2013
                          • 585
                          • CedarKey FL
                          I bet I couldnt see the hex opening because there is oil or something on it.
                          Okay, So I need 19MM headed nuts.
                          I'll most likely just weld the nuts on the rod.
                          79F
                          "Excelsior"
                          Hid headlight 6000k
                          Stock jets
                          Shinko 712 F & R
                          TC fuse block
                          Raptor 660 Acct
                            Guess you realize there is a wide external snap ring on top of seals?
                            • sparkfly88
                              • Mar 2013
                              • 585
                              • CedarKey FL
                              Yeah already got those off.
                              79F
                              "Excelsior"
                              Hid headlight 6000k
                              Stock jets
                              Shinko 712 F & R
                              TC fuse block
                              Raptor 660 Acct
                                • 8962
                                Originally posted by DGXSER
                                The setup Phil showed only has one nut on the end that goes into the damper rod, his must be held by thread lock or some welding tacks. .
                                Don, in the end of the damper rod is the head of the bolt, the 2 nuts are tightened together and with threadlock, so a 19MM deep socket and extension fit on there so it can be slid into the fork tube easily (fork lying out across the bench). The tool works great and can be stored in a small drawer until next use.
