gas leaks while running
  • ttolzmann
    • May 2013
    • 1
    • Wyoming, Minn.
    1979 1100 standard - replaced engine, using carb set from original engine. fires up seems to run/idle well, gas flowing from air box side of carbs. it seems to be coming from a hole above a jet on 3 of the carbs. Why and what to do about it?
    79 F
  • sparkfly88
    • Mar 2013
    • 585
    • CedarKey FL
    you able to post a photo or link a photo with a circle around where its coming from?
    79F
    "Excelsior"
    Honda gl1100 handlebar
    Vetter IV fairing with speaker system
    OE headers,Jardine slipons
    Hid headlight 6000k
    Stock jets
    Shinko 712 F & R
    Oe hardbags and luggage rack
    TC fuse block
    K&n filter with oe airbox
    Raptor 660 Acct
      You have at least one sticking float. Start by tapping the float bowls with the handle of a screwdriver. If they still flood, you will want to be sure the float gasket is trimmed to the edge of the bowl, so the float can not catch on it. Also make sure the float seats are good and clean.
